Question about NorStar M7310 Corded Phone
M7310 displaying maintenance mode
We a M7310 that is displaying that it is in maintenance mode. Why is it like that and how can I resolve the problem. What caused it in the first place?
    Problem Solver:
  • 4 Answers
Try unplugging the set from the jack, count to 10 and plug back in. This should request the programming from the ICS.
Posted on May 29, 2008
Phone not ringing in normal mode
I believe this is a programming issue.
To change the ringing assignments on extensions enter programming mode by pressing Feature **266344 and password 266344 if it hasn't been changed. You have to do this from an M7310 phone. The top two buttons on each side will move you through programming. The top right button is the SHOW button and the button below it is the NEXT button. The top left button is the HEADER button and the button below it is the BACK button.
Your first category should be TERMINALS & SETS. Press the SHOW button and using the dial pad enter the extension number. The display should show the extension number or name. Press SHOW three times and the display should show LINE ___.
With options to SCAN or LIST. Pressing SCAN will show the lines assigned to the extension. Use the CHNG option to change how the line is on the phone. RING ONLY - UNASSIGNED - APPEAR ONLY - AND APPEAR & RING. Change the lines you want to ring in NORMAL DAY MODE to APPEAR & RING for this extension and press SCAN to move to the next assigned line. Use this same method for any extension you want to change the ringing on.
Dec 18, 2013 | NorStar M7310 Corded Phone
How do I change the time on the display on my NorStar M7310 phone?
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Aug 09, 2010 | NorStar M7310 Corded Phone
Cannot change time on the nortel ICS phone
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
7.- Select AM or PM
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
16.- Enter month
19.- Enter day
Mar 16, 2010 | NorStar Meridian M7310 Phone
How do I reset the time on a m7310 norstar system
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Mar 15, 2010 | NorStar M7310 Corded Phone
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Engaging Maintenance Mode
Press and hold the0 , 2and OK keys together.
A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information
window.
Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode
The following keys are used to modify Maintenance Settings:
Upper and Lower Data Information Window SCROLL keys: Display the next and
previous settings.
Increase and Decrease Level Keys: Adjust the value of the displayed
setting up and down respectively, in increments of 1 unit.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Enter the Maintenance Mode (see Settings – Maintenance Mode).
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
How do i change the time
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Nov 12, 2009 | NorStar Meridian M7310 Phone
How to change time /
1.- To enter programming2.gif mode press "FEATURE" and "* * 2 6 6 3 4 4"
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___" 18.- Press softkey "CHANGE"
19.- Enter day
Nov 02, 2009 | NorStar Meridian M7310 Phone
How do i change the time on a norstar m7208 phone
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4" 2.- Enter password (default = 266344) - display should read "Terminals & Sets" 3.- Press "NEXT" 5 times - display should read "Time and Date" 4.- Press "SHOW" - display should read "Hour:___" 5.- Press softkey "CHANGE" 6.- Enter hour - display should read "AM OK or Change" 7.- Select AM or PM 8.- Press "NEXT" - display should read "Minutes:___" 9.- Press softkey "CHANGE" 10.- Enter minutes 11.- Press "NEXT" - display should read "Year:___" 12.- Press softkey "CHANGE" 13.- Enter year 14.- Press "NEXT" - display should read "Month:___" 15.- Press softkey "CHANGE" 16.- Enter month 17.- Press "NEXT" - display should read "Day:___" 18.- Press softkey "CHANGE" 19.- Enter day 20.- Press "NEXT"
Nov 01, 2009 | NorStar M7310 Corded Phone
How do i get to system programming on my norstar m7310 to get to auto relocate
Enter Administration Mode
  • Using you telephone set push feature * * 266344
  • Display will read Password
  • Using you telephone set enter password: 2 6 6 3 4 4
  • Display will read Configuration
  • Press Show
  • Display will read Trk/Line Data
  • Press Show
  • Display will read Sys speed dial
  • Press Next several times until the display reads Set relocation: Y or N
  • Press Change until the phone displays Y for ON or N for OFF
Jul 02, 2009 | NorStar M7310 Corded Phone
NorStar M7310 Corded Phone Logo
103 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
