Question about Kenmore Dishwashers
Kenmore dishwasher flashing code 7 - Kenmore Dishwashers
3 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: what does the error code on a kenmore dishwasher
Hi
To resolve this problem you will have to reset the console. Do this by closing the door and press these buttons in sequence...
* high temp wash
* heated dry
* high temp wash
* heated dry
all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it)
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Posted on Apr 17, 2010
jyackle5
  • 8197 Answers
SOURCE: 2006 kenmore elite dishwasher 665-17263402- the
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Posted on Oct 17, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Apr 29, 2014 | Dishwashers
Clean light flashing
Sorry you are having trouble, I put together a quick check list and instructions on how to reset the control. Let me know if this works for you, if not I can dig a bit deeper to help.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Apr 25, 2010 | Kenmore 24 in. 16293 Built-in Dishwasher
The clean light is flashing 7 times on my kenmore dishwasher and it won't run. What does this mean?
when the light flashes 7 times it is telling you the machine has a problem and the flash is a error code. depending on the model it could me that the heat sensor and circuit board has to be changed. check the make and model #.Go to searspartsdirect.comand you can look up parts also they can ship the parts.
Mar 06, 2010 | Dishwashers
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The clean light flashes 7 times for the code and there is no tech sheet in the dishwasher model # 565.16034402
I was able to get the coded reset on the dishwasher started but now it doesn't get the dishes clean. I cleaned the particles out of the pump assy. on the motor but some dishes still do not get clean.
Dec 27, 2009 | Kenmore Dishwashers
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
My kenmore elite dishwasher will not start.
Thanks to another post, i found how to clear this code, by alternating between the High temp dry and air dry buttons the dishwasher went into diagonostics, then cleared. I found then that the washer would fill but not wash then it would drain. I found the motor was almost seized, I am replacing. The 7 flashes must be a code for the motor going on overload.
Oct 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
135 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
