Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Need red plastic timer clips for my ML600TW. Transformer works, but only have one red movable clip for setting a time. Timer may be broken, but would like to try installing the on/off clips first. Any idea where to purchase in the Scottsdale, AZ area? No luck on-line to date. Many thanks!
Open following link for ML power pack trippers, plus troubleshoot, plus tips to keep power pack from burning out, and warranty:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 26, 2011
Have an Intermatic/Malibu ML600TW. Need to replace the terminal blocks where the transformer wires join the lighting wires. New ones from Intrermatic are wrong size. They say that's all they'
First time I've heard of this problem... and since Intermatic doesn't have exact part, I would guess the problem is not common.
Usually the trippers wear out or timer module stops or transformer burns out after power outage or bulbs burn out and are left unchanged so transformer overheats and quietly stops working.
1) Suggest use gorilla glue and stick the thing back together in that manner.
2) If the wires from transformer are connected to terminals, then you can use the flimsy plastic and glue it into place.
3) Post a photo on internet and send link so expert can see what you have.
4) Of if product is still under the 5-year warranty period, then send back to Intermatic and let them fix the product.
Copy following link for product resources.
http://www.intermatic.com/CustomerSupport.aspx
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 27, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
Ge washing machine timer plastic clips broke
go to the manufactures website and request this clip from them or go to a scrap yard and look for the same machine to take the part out of it to replace yours eric
Dec 27, 2017 | GE Washing Machines
Where can I purchase a Model #pb912m10 timer for an intermatic transformer?
The PB912M10 clock module is not sold separately.
Open following links to see available clock modules.
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
If power pack transformer still works, it might be easiest to buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Open following link for power pack resources showing tips and warranties:
Take a moment and rate answer:
Aug 29, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Lost black pin for ML600TW Malibu low voltage transformer
You can go to the Intermatic web site;
Click on customer service and then the tripper order form
or try this direct link to the form:
http://www.intermatic.com/~/media/Files/Intermatic/Other/866%20tripperorderform_6%2014%202010.ashx They're only about 10cents each so buy pleanty.
Jul 12, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
ML900wTW transformer gets stuck at the "on" position and stays there. Lights wont come on,unless I advance the wheel manualy. Then the clip will turn the lights on. The lights have no problem turning...
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
http://www.fixya.com/support/r8391011-power_pack_not_working
May 25, 2010 | Intermatic Malibu 300W Power Pack...
How do I set the timer for the malibupower pack
set the dial to the corect time by turning the dial. remove the clips by pulling straight out. reinsert clips on the desired times for on and off red on black off
May 24, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Have Malibu low voltage transformer. Need red and
Routinely vailable on eBay...sometimes listed as "Intermatic" (Malibu's parent company.).
Nov 22, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Oct 20, 2009 | Intermatic Malibu 300W Power Pack...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
140 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
