Question about Dell W3706MC 37 in. LCD HDTV
Dell 37in LCD Power-up Issue
Hi Experts, I certainly am no expert, but would really like to fix my 2 year old, out of warrenty, Dell tv...i.e. buy a replacement part direct..rather than pay the $1000 that I was quoted from the Dell Authorized OOW service provider, without parts, but included shipping. The issue is pretty simple...for the past month my tv screen has not consistently been turning on. When I press power, the blue light turns on, then there is a flicker of the screen and then nothing. If I turn it on and off it does the same thing, and it does not 'warm up' (ie go t the Dell 'warm up' screen and begin functioning). The blue light stays on and there are no other signs of failure except for the screen not turning on or properly powering up. My thought is that it has something to do with the power adaptor or something since everything else works fine when it works....I have been able to sort out some sort of solution by unplugging the tv before I go to bed and then when I need to use the tv, plug it in an it turnes on, (usually after being up-plugged for 12 hours or more). All of the features work fine and it is fully functional, but this power up issue might be related to the power adapter or something that required a 'discharge' or a reset. Can you please advise...Many, many thanks to anyone who can offer any support as other Dell TV customers know, there is not very much support out there at all.
  • 2 more comments
  • Chris May 27, 2008
    Is that why it resets and works normally after I leave it unplugged for 12 hours or so? Would this be a power issue or a 'main board' issue?
    Thank you for the advice. It seems that the capacitors might be the issue. I have a question about your hairdryer explaination. Since 'cooling' down or completely discharging the tv enables the tv to work again the 'pre-heating' method would not work, I think, because when the capacitors are hot and I turn the tv off and then on, the screen does not work, it is only when I unplug the tv for 12 hours that it properly powers up. Another question, IF I decide to open up the tv, how long would I need to leave it completely unplugged to discharge it completely? 24 hours? 48 hours?
    Thank you for your advice. I can definatly try using a multimeter, but the more that I think about it, the more it sounds like a board issue because the tv works fine for hours when I unplug it and let it 'discharge or 'reset' for 12 hours. However if I turn it on after letting it sit for 12 hours (functioning normally) and then turn it off 5 minutes later, it will not start up properly again until I unplug the tv and let it sit for another 12 hours. So that would not be a function of the power adaptor since the amps and volts should be constant whether the tv is just turning on or whether it has been on for 5 hours. What do you think?
    Thank you for your advice and help. I think that that would be the best approach to take a look at the board. How long should I let it discharge before opening it up? Many thanks!
    Scholar:
  • 139 Answers
What ill suggest if you r very sure the problem is not from the power adapter that is the one that goes to the wall then i think they should be some open circuits or broken lines. what yu do is lose the case of the lcd carefully then bring out the panel study it carefully for open circuits then resolder these open circuit n join every broken lines possibly use a brish to clean the panel for dust. couple it back carefully power on n see.most times open circuits may result to yr kind of problem
hope this helps
thank u
Posted on May 27, 2008
    President:
  • 2,712 Answers
Could be you have a couple of faulty capacitors on the power board. I would check for those first.
However, if you have no prior experience, I would recommend getting a qualified TV guy to handle this, as there are voltages in the TV that can kill..
As for replacement components, you should be able to get them pretty cheaply at your local electronics store and not have to pay the exorbitant sums DELL is charging..
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson May 27, 2008
    Here are some more tips:
    1. Try this - hold the menu button down for 10 seconds. TV
    should power up; you will have to turn off front panel buttons on menu.
    2. You can also try plugging in the TV through the USB on its panel to a
    computer or USB charger, and it may work. However, this is only a temporary
    solution.
    3. Powering down the set or putting it in standby may have
    allowed the power supply to cool. Weak capacitors often go out of spec when
    they cool, thus preventing a section of the power supply from firing up
    properly again. There is a simple trick...just warm the back of the TV with a
    hair dryer for 5-7 mins after you have unplugged the TV. Look for the little
    areas of holes in the back panel of TV. Use these as your guide at where to use
    the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make
    sure the dryer is on High heat). If the TV doesn't turn on after you have
    heated it up (like it tries to come on but then turns off) you need to unplug
    the TV again, this resets it. And repeat those steps till it works. Resetting
    the TV after it fails to turn on is the key. Also, just leave the TV on. Don't
    turn in off. Since it is LCD, it doesn't take much power...only a few bucks
    extra a month for your utility bill.
    4. A circuit board may crack about some of the larger
    components mounted on it. You can inspect the PCB's for fractures, and then
    repair them. It may also be poor soldering that has failed. I would be checking
    for these things first.
    5. If you want to go in for a long term solution, you can easily replace the
    whole power board or just change the faulty capacitors. You will have to open
    the back panel and take a look. You can make out which are faulty, because
    their caps will be swollen on top. Here's a sample pic of a bust capacitor (not
    same model):
    Check the specifications of the faulty capacitors, and get the replacements
    from your local electronics shop. If you are comfortable with this, you can use
    a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors.
    Once that is done, solder in the new capacitors carefully. If are unsure how to
    do this, try to get a friend who knows how to do this kinda stuff do it for
    you, or get a qualified technician. Warning: If you do not
    have a background in electronics repair, or are inexperienced, get a qualified
    technician to do it for you.
    REMEMBER there are very dangerous voltages inside a TV
    that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT
    THE POWER BEFORE YOU DO ANYTHING.
    Hope that helps!
  • Swilin Sampson
    It seems to be an issue with the power board and not the main board..I think the capacitors are not discharging properly. However, only a site inspection of the internals of the TV can provide any real clue..
  • Swilin Sampson
    Well, the longer it is left unplugged, the better. 10-12 hours would be fine, but to be on the safer side, I'd say 24 hrs.
    The hairdyer trick seems to work for some people, but I just provided all the possible solutions I could think of..no harm in trying, if it can save you $1000..:)
  • Swilin Sampson
    Yes..the issue is most likely the power board..
  • Dell Master
  • 19,396 Answers
The safety switch is coming up, there is an internal fault, may be overvoltage or something has blown
  • Ginko
    Ginko May 27, 2008
    If it is just the power adapter you can get replacement from dell. To test the power adapter you need a Multi-Meter, you need to check the voltage coming out and that power is not being cut off.
    If it is the power adapter you can just replace it. Buy the spare from dell, or type the power adapter part number in google and see what you find.
    It can also be an overheating problem, some board, like audio board and main pcb inside has a termic sensor shutting down the device when overheating. In this case I suggest calling a repairman
Red line on sceen?
I had a similar problem with my LCD screen TV, and to my dismay, my warranty just ran out. A thin red line began to appear on the right side of the screen, and since many online and expert sources pretty much say replace the expensive LCD screen or get a professional to fix it (in which I suspect to be a business plot to get people to go to pricey experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10 minutes. Turn it back on and see if it disappears or improve. (This is the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV (cables, power chords, etc.); you could even try unplugging and replugging the chords/cables. Turn the TV back on and see if the red line disappeared or improve. (This is the one I heard worked for others.)
If the above doesn't work then I'm afraid you do have a bad panel on your screen and will need to call in the experts or get a new TV. I hope this will help. Best Wishes.
Nov 12, 2012 | Dell E207WFP LCD Monitor
Why is my new samsung lcd 32 inch getting on and off again and again it self? and a voice it coming from the back part too.?
Under a year,this tv was bought?Tv still have warrenty,call Samsung for warrenty repair.Not.Tv power on have flashes of pictures,few sec.than dies,have only sound left?Yes.Ur tv have dead 1 or 2 long board call the LCD inverter boards.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produre a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 LCD inverter long boards for the replacement.
Aug 09, 2010 | Samsung LN32A550 32 in. LCD TV
No power
This model has been reported to have TWO band capacitors on the power supply. The reason why it is not powering is because of this issue.
You will need to open the unit and change these out.
WARNING!
fIXYA IS NOT RESPONSIABLE IR LIABLE FOR DAMAGE OR INJURY RESULTING IN THIS SOLUTION NOR IS THE EXPERT THAT IS INSTRUCTING YOU. iF YOU NOT EXPERIENCED I NTHIS AREA BY ALL MEANS LEAVE IT TO THE EXPERTS LOCALLY.
1. OPEN UP THE UNT.
2. YOU WILL FIND THE POWER SUPPLY UNDER BASICALLY A METAL BOX WITCH NEEDS TO BE OPENED.
3. YOU NEED TO LOCAL THE TWO CAPACITORS AND REMOVE THEM WITH A SOLDER IRON.
4. YOU NEED TO ORDER THESE FROM RADIO SHACK OR EBAY, OR ANY ELETRONICS SPECIALTY.
5. YOU NEED TO MATCH UP THE POLARITY/VOLTAGES AND uf RATINGS AND PUCHASE THAT CAPACITOR.
6. INSTALLTION OF THIS CAN GET MESSY AND YOU DO NEED SOME SKILL, SOLDER THE TWO IN WHERE THE OLD ONES WHERE MAKING SURE YOU GOT YOU NEGITIVE AND POSTIVE POLES IN THE CORRECT HOLE'S.
Thanks for visitng fixya.com you where just provided a step by step of how we fix things here, please be considerate and rate all experts involved in your case with postive feedback and ratings. Thanks
Jul 01, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Tele wont turn out on just got light falsing on button and tickin noise
known fault samsung will fix for free they did with mine my tv was 3-4 years old they fixed it june 10 let the experts fix it
Apr 25, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Tv wount turn on
accidentally put usb plug in service port, power gone no tv.. or vizio light..
Feb 28, 2010 | Vizio VW37LHDTV40A 37 in. LCD TV
ARPI your the guru please HELP ME I just need to fix this TV
Dell will replace it if it's less than 3 yrs old but apparently their tech support people are clueless about this and have to be told what they need to look up. The replacement is a nice gesture except if you're like me and paid >$1,000 for this more than 3 yrs ago. I have had TV's > 20 yrs and don't reacall major problems with any.
These instructions were posted on the Dell Community forum http://en.community.dell.com/forums/
The following in and out of warranty TVs (W2600, W2306C, W2606C) with the No Power issue must go through Technical Support to initiate the exchange. Tell the technician to look up the following DSN document IDs to get the details on the in and out of warranty exchange process:
- 313698 Dell-Branded TVs Out-of-Warranty Repair Procedure - CTS/CBG/SMB/GTS-T/DOC. Tell them to scroll down to, Dell W2306C, W2606C, or W2600 TV Replacement for a No Power Issue
- 329986 TVs (W2600, W2306C, W2606C) with No Power. New exchange procedure - TV and Home Theater - Dell Community Forum
* Dell will cover this issue, regardless of the limited warranty status, for the W2306C, W2606C or W2600 TVs for 3 years from the original invoice date
* Once past the 3 year date from the original invoice date, we will not exchange the TV
* Units sent as replacements for this issue should be considered in warranty for 90 days after the replacement or for the remainder of the limited warranty term, whichever is longer
* You will need to provide to them the following information -
TV Service tag number:
TV Order number:
Name:
Shipping address:
Phone number:
Email address:
Reason: Dell LCD TV has the No Power issue
Jan 02, 2009 | Dell W2600 26 in. LCD Television
Sound on TV
I to have a sound problem with the W3201''
I too have a sound problem witn the W3201C 32 inc LCD TV. My set is a mere 2 years old. the sound pulses when turned on, however after about 20 mins or so wih the sound muted, the sound does clear up - how long this fix will work is anybodies guess and when that fix goes, what then. I have phoned Dell and they told me they no longer make either this TV or the parts to repair it. I REALLY dont think we should silently put up with this
shoddy workmanship, If Dell refuses to replace these defective TV's, which were certainly not cheap - I for one am seeking legal counsel
c
Jul 17, 2008 | Dell W3201C 32 in. LCD Television
Thin Red Line on LCD TV
Apr 01, 2008 | Televison & Video
Dell W3706MC 37 in. LCD HDTV Logo
289 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
