Question about Fisher and Paykel GWL11 Top Load Washer
My washer pour water just from the back hose ... doesn't suppose to pour water from the right side of the washer ? it used to do so..but not anymore
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now can you tell me where the machine is leaking the water from.Is the water coming out of the black drain hose?Or is the water leaking from the inlet hoses from the taps? Or is it leaking under the machine?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Oct 04, 2010
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
Washer stoped and did not finish rinse cycle now it makes a humming sound and code nd
Washer Error Codes ND IS -No Drain There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is sliping or broken
  1. Unplug the washer from the electric outlet.
  2. 3Open the case, and disconnect the water hose from the outlet of the water pump.
  3. 4If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
  4. 5Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
  5. 6Reassemble hose from step 3.
  6. 7Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
  7. 8Reassemble washing machine case...you're done...
Oct 11, 2011 | Washing Machines
The washer will not complete the cycle. It will not drain and spin.
There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is slipping or broken.
1 Fill washer with water and wait for the timer to get to the drain mode.
2 Unplug the washer from the electric outlet.
3 Open the case, and disconnect the water hose from the outlet of the water pump.
4 If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
5 Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
6 Reassemble hose from step 3.
7 Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
8 Reassemble washing machine case...you're done...
Jun 16, 2011 | Washing Machines
Water pouring out of cold water connection the hookup is only connected to the hot water because the steam hookup is suppose work for hot water.... So they say??????!!! Is there suppose to be another hose...
YES YOU NEED TO EITHER PURCHASE A SCREW ON PLUG FOR THE COLD SIDE OR HOOK UP A HOSE FROM A COLD WATER VALVE TO THE COLD SIDE OF YOUR INLET WATER VALVE ON THE WASHER (YOU SHOULD HAVE GOTTEN A HOSE WHEN YOU BOUGHT IT, IF NOT YOU CAN PURCHASE ONE AT YOUR LOCAL HARDWARE STORE OR APPLIANCE PARTS STORE , OR SEARS PARTS DIRECT. LET ME KNOW IF THIS WAS HELPFUL!
Mar 10, 2011 | Frigidaire Washing Machines
I have the kenmore HE2 front loader. when you turn it on now water comes pouring out of the detergent filling compartment and flooded the house... any ideas
there is a water inlet on the right side of the detergent filling cup to flush out the dry detergent. take out the fill and it is midway back on the right(little rubber hose) once you locate that take the top panel off and follow the hose, should lead to a silinoid. this is most likely sticking open, or the line is broken and dumping water into the washer cavity instead of in the detergent cup. hope that gets you started in the right direction.
Jan 17, 2010 | Kenmore 43142 Front Load Washer
Condensation at top of inside refrigerator
you have a drain hose from the top back of the freezer down to the condensate pan on the bottom of the refrigerator near the floor
this hose is blocked causing ice to build up behind the rear inner wall.
remove the back of the freezer wall and using a funnel pour hot water in to the hose to clear the condensate hose also remove all the ice behind the wall; remove the back cardboard to see the water come through the hose into the condensate tray when you pour the water it should pour right through if it's clear
Aug 31, 2009 | GE Refrigerators
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Whirlpool washer pours water on right side
The pumps on these washer wear out over time and leak.
While replacing the pump, you should replace the direct drive coupling also. That is part of the torn rubber gasket you are referring to.
This video will show you access to the parts.
Apr 22, 2009 | Whirlpool Washing Machines
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks/pours out
its very difficult to answer your question since different machines use different pumps. as for the leak my guess is either a hose has disconnected/torn at the pump or inlet water valve.
Sep 18, 2007 | GE WSM2780W Stacked Washer / Dryer
Fisher and Paykel GWL11 Top Load Washer Logo
47 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
