Question about Canon PowerShot S230 / IXUS 179 Digital Camera
No pictures Suddenly my Canon S230 does not write to the compact flash card. I've swapped out cards to no avail. Flash, display are normal. I've used the camera for 4 years and am completely familiar with its operation. I'd hate to think it is dead. EllenB
  • ecb01701 May 28, 2008
    Thanks. Pins look OK. I should add that I had taken a few pix on Monday and saw the image on the LCD. On Friday, my next use, the LCD showed a few white lines and grey boxes instead of the image, eventually showed nothing except the menu setting that appears/disappears when I press the "display" button. Downloads were plain black boxes, one for every attempted picture.
    Thank you very much. I'll call Canon tomorrow > I would never have found that URL, and I really love this camera.
  • Canon Master
  • 4,738 Answers
Look in the card slot with a flashlight to see if there are any bent / misaligned pins. If so, remove batteries and card and Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed). It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on May 28, 2008
My card won't work on my computer, what is wrong?
When you format the card, be sure to do it in the camera, as the camera firmware writes hidden files to the card.
When you insert the card into the card reader, be sure to set write-protect, so the contents cannot be corrupted.
I suspect what may have happened is that at some point there has been a conflict between files written to the card by the camera and the computer.
May 13, 2017 | SanDisk ULTRA II 4GB Compact Flash Card...
I have a Canon EOS 350D, Compact Flash card freezes my computer
Instead of connecting via the camera, just use a USB card reader and put the CF card in that.
Mar 17, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Retrieving deleted pictures from compact flash card
If you're runnng a Windows system, you can try an undelete program such as the following:
http://www.freewarefiles.com/Undelete-Plus_program_24002.html
Usually, when you delete pictures from a flash device, it just sets a tag at the beginning of each file name telling the compact flash file system that the files can be overwrote. The most important thing to do at this point is not take any more pictures or copy any files to the card. Try downloading and installing that program [it's free] and choosing your card as the drive to scan [if you use a card reader this will be easy, if you use a camera, it may not show the camera or card as a device in My Computer].
Mar 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Compact flash card
It can if it is compatible, meaining I use the Canon and I have to use the type II cards, it accesses fine.. I wouldn't go to the type IV as I have heard they hang when acquiring pictures.
Jan 29, 2009 | Nikon Coolpix 5700 Digital Camera
Internal memory??
Highly recommend that you consider using a card reader to download you pictures. You insert the camera's memory card into the reader, and then insert the reader into a USB port on your computer. The card then shows up as a hard drive so that you can simply copy/paste or drag your picture files onto your computer. Card readers are much more faster in downloading pics, do not require the use of your camera's batteries, and provide much more reliable downloading of the pictures (fewer errors). They're also VERY inexpensive these days. Here are some examples of CF card readers from Amazon:
http://www.amazon.com/s/qid=1223745821/ref=sr_st?keywords=cf+compact+flash+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acf+compact+flash+card+reader&sort=price
Also, if the card has somehow become corrupted, take no more pics until you've recovered the photos. Take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will also need to use a card reader with this software. Finally AFTER you've recovered your photos, recommend formatting the card IN YOUR CAMERA to prevent this from happening again. Note that formatting will totally erase your card. Turn on the camera, press the menu button, select the tools menu. Go down to the selection that states your CF card's memory capacity and select it. Then follow the formatting prompts.
Oct 08, 2008 | Canon PowerShot A75 Digital Camera
Compact Flash Card
any size your looking for ... probally not larger than an 8 gb card would be fine
Apr 20, 2008 | Canon PowerShot S230 / IXUS 179 Digital...
Canon powershot S230 Camera will not take picture now
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Oct 28, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards: 1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. 2. Warning message "Unidentified PC Card Adapter". 3. Warning message "Storage Card Warning" displayed. To fix these issues: If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Canon PowerShot S230 / IXUS 179 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
