Question about Canon PowerShot A540 Digital Camera
How do u restart the camera whe the lens dont work?
  • 38 Answers
Remove the card, then try to restart your camera and tap the lens barrel with a wooden pencil from one side. Then try to blow some compressed air under the lens barrel,maybe is sand stuck in there.
Posted on Oct 04, 2010
Y have a ixus 60, no I got the " lens error, restart the camera" When I sart the camera, I nowt hear nothing a then comes the piepie with Lens error, restart camera. This happend when whe make...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jan 07, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Len extended will not retract and the green led on the back tilt whe I keep press the power button
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2010 | Insignia NSDSC10A Digital Camera
Whe I turn the carmera on it says lens error and then the whole camera shuts off, I am not sure what to do . Is it broken?
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 02, 2010 | Kodak EasyShare C713 Digital Camera
LENS ERROR ON KEEPS COMMING UP.HOW DO YOU RESTART IT?! WHY TELL YOU TO RESTART IT WHEN YOU DONT KNOW HOW TOO?IVE LOOKED EVERYWHERE
Lens errors are fairly common. As you've found, the recommendation to restart (turning the camera off and then back on again) usually does not work. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 14, 2010 | Canon PowerShot A480 Digital Camera
Lens error, restart the camera. How to retart. The zoom lens projected is not getting back again When the camera was on, the zoom lens cameout and got struct and not going inside. we get a instruction as...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 01, 2009 | Cameras
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Aug 02, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error appear and it needs to be restart,i cant restart the camera because i dont know the symbol of re-starting.
Jul 24, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens error restart camera
Pls use the fresh batteries & slite rotating of lens.
( dont's over presure )
B. rgds
Rajnish
rajnish@orientaldelhi.com
Mar 21, 2009 | Canon PowerShot A470 Digital Camera
When i go to turn the camera on it beeps and says lens error restart camera. I dont know what to do!
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Nov 01, 2008 | Cameras
Canon PowerShot A540 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
