Question about Honda Pressure Washer PSI 3000
My Honda 2600 psi power washer will not pull to start. It was running great then I allowed the neighbor to borrow it. He ran the washer till it was out of gas and proceeded to refuel and at this point it would no longer start. The pull cord is out about 4-6 inches out and I am concerned about taking the casing off myself. Fearing that it may throw more off on the unit. If i take the casing off are there any spring loaded parts that will dismount? What should I do? Spark Plug? Turn wrenches? Please let me know
    Scholar:
  • 100 Answers
You should be fine to take the recoil off, there shouldn't be anything that shoots out at you. You might want to check the oil level on the engine, many of the Honda engines won't start unless there is enough oil in them. If your oil level is fine, check to make sure that your motor is getting spark.
Posted on Oct 25, 2010
Gcv160
Clean it up real well and try again. Most likely the oil is from the motor being put in a position that allows the oil to run into spots that it is not supposed to be in.
May 17, 2013 | Honda Black Max 2600 PSI Pressure Washer
How to start
place the fuel valve on then choke to start position for a couple pulls then place choke in the middle and pull a few more times it should start by then
Aug 10, 2012 | Honda Black Max 2600 PSI Pressure Washer
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
Honda Pressure Washer PSI 3000 Logo
290 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
