Question about Weiser Lock Powerbolt 1000 Lock
The lock works in reverse order. I have to put in the code to lock the door, and just have to press the middle (lock) button to unlock it. I have changed the door direction jumper in every possible way. What is wrong?
  • jbureau99 Oct 05, 2010
    as noted above I already changed the jumper. Got on the phone with Weiser, went through the motions, and they are sending me a new motherboard, I hope!
    Problem Solver:
  • 17 Answers
Change the door direction jumper as outlined in this article - http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Posted on Oct 05, 2010
Why do the headlights. Come on when any door is opened on my 2008 trailblazer
The Headlamps On at Exit and Perimeter Lighting modes can be adjusted using the steering wheel controls to select the wanted function as displayed in the driver information center. The Headlamps On at Exit selection will allow the driver to customize the period of time that the headlamps remain illuminated upon exiting the vehicle. This period can be adjusted from 0 seconds to 180 seconds. The Perimeter Lighting feature allows the driver to select if they want the headlamps and backup lamps to illuminate when the door UNLOCK button on the key fob is activated. This feature can be turned ON or OFF by using the driver information center steering wheel control buttons.
programming Features with the Driver Information Center (DIC)
To enter programming with the driver information center (DIC), perform the following actions:
Turn the ignition to RUN.
Place the vehicle in PARK.
Press the Personalization button on the steering wheel to enter personalization programming.
Automatic Door Locks
Continue with the following steps in order to personalize the automatic door locks:
Press the Select button in order to enter the menu. The first choice seen is the current setting.
Press the Select button in order to scroll through the following options:
• LOCK DOORS: IN GEAR
• LOCK DOORS: WITH SPEED
Press the Personalization button in order to advance to the next option.
• UNLOCK DRIVER: IN PARK
• UNLOCK DOORS: IN PARK
• UNLOCK DOORS: AT KEY OUT
• UNLOCK DOORS: MANUALLY
Remote Activation Verification
Continue with the following steps in order to personalize the remote activation verification feature:
• LOCK FEEDBACK: BOTH
• LOCK FEEDBACK: OFF
• LOCK FEEDBACK: HORN
• LOCK FEEDBACK: LAMPS
• UNLOCK FEEDBACK: BOTH
• UNLOCK FEEDBACK: OFF
• UNLOCK FEEDBACK: HORN
• UNLOCK FEEDBACK: LAMPS
Delayed Lighting
Continue with the following steps in order to personalize the delayed lighting feature:
• HEADLAMP DELAY: 10 SEC
• HEADLAMP DELAY: 20 SEC
• HEADLAMP DELAY: 40 SEC
• HEADLAMP DELAY: 1 MIN
• HEADLAMP DELAY: 2 MIN
• HEADLAMP DELAY: 3 MIN
• HEADLAMP DELAY: OFF
Perimeter Lighting
Continue with the following steps in order to personalize the perimeter lighting:
• PERIMETER LIGHTS: OFF
• PERIMETER LIGHTS: ON
Mar 13, 2017 | 2008 Chevrolet Trailblazer
My 323i was stored for 2 years. I am now getting it road ready and the passenger front, and both back doors wil not unlock. can you help?
Hi, try this as it may or may not apply to your model.Get in, open and close the drivers door, put key in ignition turn 2 clicks and take back out again, within 5 seconds, hold the 'lock' button in the middle of the key and press the 'unlock' button 3 times, then let go. Quickly repeat the lock and unlock button sequence on the spare key. All doors should lock and then unlock when it has worked.
Jan 24, 2011 | 1999 BMW 323 Series
It's working in reverse order - I have to put the code in first to lock it, which leaves it ready for someone to break in because all they have to do is press the lock button and it will open. How do I fix...
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
his should help:
https://s3.amazonaws.com/Kwikset/Powerbolt%201000%20-%20Installation%20Instructions.pdf
Kwikset and Weiser are part of the same company now.
If the above link doesn't work, this is from their site:
Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
Remove the inner cover plate from the lock.
Locate the small round program button near the left side of the circuit board (Red or Black).
* To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
* To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
Apr 14, 2010 | Weiser Lock Powerbolt 1000 Lock
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
I don't have a manual for my 2004 lincoln Avaitor but would like to know how I can change the code on the drives door key pad
KEYLESS ENTRY SYSTEM With the keyless entry keypad, you can: • lock or unlock the vehicle doors without using the key. Your vehicle has a factory set 5 digit code that operates the keyless entry system. You can also program your own 5 digit personal entry code. The factory-set code is located: • on the owner's wallet card in the glove compartment • or at your dealer. When pressing the controls on the keyless entry keypad, press the middle of the controls to ensure a good activation. This system will disable the power door lock controls. These will not work until the vehicle is disarmed. Programming your own personal entry code To program your own code: 5. Enter factory set code (keypad will illuminate when pressed). 6. Press 1/2 control within five seconds of step 1. 7. Enter your personal 5 digit code. Enter each digit within five seconds of previous one. 8. After the code is entered, the locks will cycle, confirming that the new code has been set. Do not set a code that includes five of the same number or presents them in sequential order. Thieves can easily figure out these types of codes. Your personal code does not replace the permanent code that the dealership gave you. You can use either code to unlock your vehicle. If a second personal code is entered, the module will erase the first personal code in favor of the new code. Locks and Security 149 Locks and Security If you wish to erase your personal code, use the following instructions: 1. Enter factory set code. 2. Press 1/2 control and release. The system will now only respond to the factory set code. Anti-scan feature The anti-scan feature prevents repeated attempts at arriving at a valid key code. The keyless entry pad is disabled for 1 minute after 7 unsuccessful attempts (35 consecutive button presses) at entering a valid key code. The keypad will flash during this 1 minute mode. However, the 7/8 and 9/0 controls will still lock the vehicle. Anti-scan will be turned off after: • one minute of keypad inactivity. • the remote entry transmitter UNLOCK button is pressed. • the ignition is turned to the ON position. Unlocking the doors with the keyless entry system To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will also illuminate. To unlock all doors, enter the factory set code or personal code (driver door unlocks) and press the 3/4 control within five seconds. Locking the doors with the keyless entry system It is not necessary to enter the factory or personal code prior to locking all doors. To lock the doors: • with the driver's door closed, press the 7/8 control and the 9/0 control at the same time.
Dec 17, 2009 | 2004 Lincoln Aviator
Got the car back from bodyshop same thing no clock or radio and keyless entry problems
Sounds like they disconnected your battery when they were working on your car. Your radio probably requires an unlock code to get it to work again which you'll have to get from a dealership with proof that the car is yours.
They key fob will also have to be reset.
  1. Close all the vehicle doors.
  2. Insert the ignition key into the ignition lock cylinder.
  3. Press and hold the door unlock switch.
  4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Turn the ignition switch to the On position in order to exit the keyless entry transmitter programming mode.
  8. Operate the transmitter functions in order to verify correct system operation.
Sep 09, 2009 | 2005 Kia Spectra
How do i program a new remote for my 2001 chevrolet blazer?
You may program up to 4 transmitters, using following procedure:
Transmitter Programming Procedure (No Tools Required)
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
May 06, 2009 | 2001 Chevrolet Blazer
Center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Jan 22, 2009 | Weiser Lock Powerbolt 1000 Lock
Keyless entry
I believe dealer has to re-program the new code.
Aug 29, 2008 | 2001 Ford Explorer Sport Trac
Weiser Lock Powerbolt 1000 Lock Logo
237 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
