Question about Hitachi 36UX01S 36" TV
The image on the TV has sort of condensed and disappeared. Now there is a bright line across the middle of the screen and a sliver of (about an inch) of image above that line. The rest of the screen is all black (no image)
  • Hitachi Master
  • 1,210 Answers
You have a vertical output IC that needs repaired. You may need to only resolder the vertical output IC. If then you do resolder, you will need to check and replace any capacitor in the immediate area of the vertical IC. A weak or bad capacitor will heat up the IC, and create rings on the pins under the IC. Also check the solder grounds on any resistor and diode that are immediately near this IC. This will bring your TV back to full view. Thanks for asking and show a few hands of support!
Posted on Oct 04, 2010
We get sound but just a bright line across the middle. Tv is probably a 1994 model
there is a problem with the vertical section its either defective ic, defective capacitors no supply or just loss contact.Try to check all of these and its probably help your problem.
Mar 06, 2015 | Sylvania Televison & Video
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
A line has appeared across the bottom of the screen and also along the middle. the bottom line is white/red.blue and the middle line is mainly green
If your TV is still under guarantee then change it asap, if not you have a problem, the panel has failed, in very rare cases the lines will disappear when the set is at its maximum operating temperature, that said it will never be 100% again, sorry
Apr 19, 2010 | Grundig GU26DVD 26 in. LCD TV/DVD Combo
Old sony tv gets a bright line in the middle of the screen
Well if this is a tube type, it can be attributed to vertical section. Cold solder on vertical IC, the vertical gone bad or some components on the vertical is at fault.
If your not on electronics better to have it check by a repairer.
Hope this helps.
Jan 18, 2010 | RCA F32650 32" TV
White lines across image
SHould only be seen on camera screen, should be all better when viewed on computer, that happened to me too!
Aug 02, 2009 | Nikon Coolpix 5700 Digital Camera
The image disappears on my tv screen. A horizontal line appears.
You need to check the horizontal IC for deffects, possibly and most likely there are dry joints on the legs of the Horizontal IC. Have all the legs on the IC soldered nicely, this shud sort out your problems as you say you hit the TV then works. Try this before replacing the IC
Apr 16, 2009 | Televison & Video
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Hitachi 36UX01S 36" TV Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
