Question about Janome Memory Craft 3000
It is hard to use the needle threader can't get thread to go thru needle am I using it wrong? Thread in front of needle or behind needle I have tried both.
    Genius:
  • 1,788 Answers
Takes a little practice, just be patient, the thread goes in front of the needle. Sometimes the needle hole is very small and addes to the frustration. I use Singer Inspira needles and they have a larger hole and much easier to thread.
Posted on Oct 04, 2010
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
How to thread a singer hand held
Thread should flow from top right of bobbin or spool and the spring must be in place before installing the bobbin.
1. Thread the handy stitcher
2. Pass thread through hole on the thread guide which sticks out from the side of the needle arm.
3. Pass thread through top of the tension control between the plates, but don't wrap completely around the tension control.
4. Then pass the thread through the thread guide located on the bottom side of the needle arm directly behind the needle.
5. Use threader to pass thread through eye of the needle from back to front (opposite of a "real" electronic sewing machine.
Hope this helps.
Jimmy
Mar 29, 2012 | Sewing Machines
How do you thread a pfaff 7570
If only we could put video links in here! But here goes:
Raise the presser foot;
Turn the hand wheel until the take-up lever (the hook bit that goes up and down, above the needle ) has reached its highest position;
Remove the small spool holder from the horizontal thread holder that is under the lid. Put thread reel onto spool, replace spool holder;
Pull thread behind first thread guide - it is the cream flat plastic bit towards the back - about 1" x 3/4" (i.e. the thread takes the first exit at the back);
Bring it down the left-hand long slot on the front of the machine, back up the right-hand slot, over the hook of the take-up lever, back down the right-hand slot and pass it from the side between the thread guide (silver metal bit just above the needle - looks a bit like curled metal). I found this last guide the most difficult to figure out - tried to get the thread into the curled bit - but you don't do that - it just slips in behind;
Thread goes through the eye of the needle. You can use the needle threader or not. Instructions for needle threader:
Lower sewing foot (makes more room and clamps the thread in the upper tension discs so it is less likely to keep spooling off while you are trying to thread);
Turn handwheel until the needle is in highest position;
Pull the needle threader straight down and then twist it to the front so the tiny hook on the threader goes through the eye of the needle;
Take thread under the larger metal hook on the left, put your thumb on it to stop it coming off, thread goes back towards the needle and under the small hook that is poking through the needle from the back;
Twist the needle threader towards the rear, releasing the thread carefully and allow the threader to move upwards. There should be a loop of thread left in the eye of the needle and you can now pull it all through to the back.
That sounds really complicated but I find the Pfaff needle threader works really well, unlike that of some other machines. I also have a Husqvarna Designer 1 whose needle threader works great, but the one on my friend's Designer SE is useless. Go figure!
Feb 02, 2010 | PfaFF Creative 7570
How do I use the automatic threader? The diagram in the instruction manual just shows the threader but doesn't show how to get the thread in.
When you have the threader engaged to the needle hold the thread between your two hands horizontally and slide the thread behind the needle starting from the bottom up until you feel it stop then pull the threader gently out toward the back of the machine. Sometimes it takes a few tries to get the hang of it
Jan 20, 2010 | Sewing Machines
How do I theard the needle on the 5050C singer machine?
does the machine have a needle threader? first if so, pull it down and put the thread behind the left side of the threader and loop the thread around toward the needle then go behind the finger of the threader hold the thread back against the needle and slightly pull upwards pull the threader forward and gently let go with the right hand of the thread and the needle will pull the thread through, second if the machine doesn't have a threader, the easiest way to thread a needle is to buy a needle threader, it is a device that you put through the eye of the needle and put the thread through its hole then just pull the threader back out and the needle is threaded.
Aug 22, 2009 | Sewing Machines
Show me how to use the auto threader
Thread the machine to the point where the thread is in the needle bar thread guide. With you left hand hold the upper thread towards you. With your right hand pull down on the threader unit and twist it so the tiny hook goes through the eye of the needle and hold it there. Now take the thread that you are holding in your left hand and pass it to the rear of the machine under the small guides on the threader hook. Release the threader mechanism and the thread and the tiny hook should pull a small loop through the eye. Pull on this small loop (which will be on the right side) all the way through the eye.
Viola!
good luck!
Jan 31, 2009 | Juki TL-98Q
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Threading & Use of Needle Threder
Threading as per image....make sure presser foot is up so top thread will properly engage in tension unit, make sure your thread is inserted in small guide on needle arm too. Your user guide should have a clear graphic of this process which is essentially the same for all machines.
As for the needle threader, once thru the last guide on the needle arm, raise needle to highest position, lower the needle threader so that the tiny hook engages the eye of the needle and place thread horizontally from L to R along the plastic arm so the tiny hook can grab thread, release threader and a small loop will form in needle, pull it clear and you are away !
If the tiny hook has been bent, a little judicious and gentle bending to re-align may be necessary, use a jewellers screwdriver or similar and please be very gentle
Feb 07, 2008 | Janome Jem Gold 660 Sewing Machine
Automatic Threader Never works
lever the auto threader slightly back and pull down- if it doesnt pull down adjust the needle up or down slightly. Once it is down behind the needle, place thread under far left of threader then pull across to far right and hook behind tiny hook. Sounds complicated but not so when you get the basic action. Release and guide back up and the thread should be thru the hole and looped up bahind it. Hope you get it.
Jan 29, 2008 | Janome D'cor Excel Pro 5124 Mechanical...
Automatic threading
Although I do not know this model, the philosophy of these types of threader is to place the thread horizontally to the needle across the needle hole while a tiny hook comes towards you thru the hole and pulls a loop of thread with it, you grab the loop and pull it free.
(Some older Janomes have a device that pushes from front to rear)
The tiny hook can and does get bent, so get a magnifier and just check it is functioning....if it is missing the needle eye, a small implement, like jewellers screwdriver etc may be used to gently straighten and re-align....they are quite sturdy, but be gentle.
Once you have a look at the device under magnification you will also much better understand how it works, and know where the thread needs to be for it all to come together !
Apr 28, 2007 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
77 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
