Question about HP PSC 750 All-In-One InkJet Printer
Pink photos changed colour cartridge with refill now every photo is printing in pink.
The cartridge had a blockedge and once cleaned all colours were primed and ready to print
Posted on May 28, 2008
Cannon mp560 photos are printing all a pink colour
it sounds as if one or more of the nozzles of your printhead is dried or blocked. I would advise printing printing a test page like this one to clarify the cause.
Assuming one of the colours is missing (i would imagine it would be cyan or yellow) then run some head cleans from your printer software or the printer itself.
Sep 06, 2012 | Canon MP560 All-In-One InkJet Printer
All my photos come out in a pink colour
Hi this can mean two things:
1., the nozzles on the cartridge need cleaning => print a nozzle cleaning page (it's in the printers software, if this does not work you may try taking the cartridge out and cleaning the bottom with warm water (be careful, dry it before putting back)
2., the cartridge ran out of blue or yellow color => replace it or get it refilled
Mar 20, 2011 | Cannon Office Equipment & Supplies
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ip5000 just stopped printing colour in middle of photo
are your rubber washers still in place? Are you using OEM cartridges or refilled?
Dec 29, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
Can't print photos with correct colours. Photos in .jpg format and I know colours on screen match colours when printed commercially. Printing from Zoom Browser or Canon Easy Photo gives much worse results...
First clean the print head and run the test print and then the alignment setup to make sure that the printer is clean and registers correctly. In the Printer Properties (Right click on the printer name via Control Panel - Printers) there is an option tab for Colour Management. Click this and select the source that you need to match the print output to. Also go through all the other tabs in Pinter - Properties as there are many setup options there to setup and tweak the colour balance and adding effects etc. This can be quite a lengthy process but well worth the effort. There is no shortcut to doing this but you will end up with a precisely calibrated custom printer setup that you can save and reuse at any time. I have these profiles defined for my printers for each media type and each ink supplier although I have minimised the number of profiles by now using 1 bulk ink supplier to get consistency between cartridge changes and CISS refills. Note that this may vary when you change print carts or change the media type and manufacturers.
Oct 07, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
My photos are coming out Pink tinted. I Have new cartridges installed, can this be fixed?
Could you do a "diagnostic" print? As it might be that the colours con your tricolour cartridge have been cross-contaminated**
To test the purity of the colour just go to word, excel or any other application, Create a document that has pure colour squares or you can print page 1 of this link . Then compare the colours of the page on the screen versus what you got. if the colours are off, it means your cartridge has been cross contaminated. Sadly a cross contaminated cartridge can't be fixed. So if you just bought it I would recommend you return it :(
Cheers, Ed
**: (this could be the results of refilling, storing the cartridge in the wrong container or on very rare occasions a HP manufacturing issue).
Oct 04, 2009 | HP PhotoSmart 7960 InkJet Printer
Hp 110 ( cb304A ) some of these cartridges they print colours wrong, let's say instead of Cyan/Magenta/Yellow they print it backwards Y/M/C WHY?
if you have refilled the cartridge, then it shows that cartridges are not refilled in correct order.
change the cartridge
Sep 16, 2009 | HP Photosmart A526 photo printer
Canon S520 printer colours not correct
i think its time you replace/refill that ink cartridge. some of the colors must have run out.
Sep 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
HP PSC 750 All-In-One InkJet Printer Logo
66 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
