Question about Goldstar KG6000R Window Air Conditioner
My air conditioner is trowing water true the inside of my window insted of outside why is this happening?
Your drain tube or holes are plugged up
Posted on Oct 04, 2010
  • canales627 Oct 04, 2010
    Hi thanx for answering my ? So what should I do with my problem do I buy a new piece or does it not work anymore I need my ac ...thanx
  • randolphkevi Oct 04, 2010
    you need to take unit apart and clean. make sure the unit is not leaning forward should lean back a little bit.
How much should my air conditioner be tilted in the window
Window air conditioners generally should be mounted with a slight downward tilt toward the outside. This allows condensate to drain outside rather than inside.
May 02, 2013 | Kenmore Heating & Cooling
My Frigidaire Window Ac Unit is Collecting Water on the Styrofoam Thats Facing Inside The Home By The Vents,Why Is this Happening?
tilt your ac down on the outside,so it will drain properly,if that doesnt help,pour some bleach in the water inside to get rid of mold that clogs the drain
Apr 18, 2017 | Heating & Cooling
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Air conditioner leaking water outside and inside the window. what should I do?
first try to tilt it more to the outside if this does not fix the problem the drain holes are plugged between the inside coil and the outside and possibly the hole on the outside. Its usually best to remove the unit and wash it out outside. try not to get water on the switches.
Aug 08, 2010 | LG BG8000ER Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Emerson quiet kool wall air conditioner. Should vent be open to remove humidity?
No - opening the vent will allow unconditioned outside air into the space and add to the humidity load.
Think of it like your car's A/C - when you put the controls to "Max A/C" the system recycles just the air inside the car and doesn't use any outside air. When the control is set to normal A/C, some outside (fresh) air is brought in.
The same thing is true for a window A/C unit. Keeping the vent closed will help the unit de-humidify and cool the air more quickly.
Jul 12, 2010 | Emerson Quiet Kool 12NW46K Air Conditioner
Blowing water out the vents.
There is a water pipe from AC to outside,
if a lot of gel inside the pipe, it can make water flow become jam.
Clean it by blow the pipe with a compressor from outside.
Sometimes I did it with my mouth. LOL......
But its worked finally.
Sep 06, 2009 | Goldstar LG LW1804ER Window Air...
Water running out the back and standing inside the cabinet
this i supposed to happen there is a slinger that sprays water on the outside coil to cool it and evaporate water but some will come out when it get to full
Jun 26, 2009 | Haier ESA3185 Thru-Wall/Window Air...
Water not draining out the back
Humidity is where the water comes from. If humidity is low, very little if any, water.
Jun 23, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Goldstar KG6000R Window Air Conditioner Logo
62 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
