Question about Panasonic Televison & Video
Green and red colors is out of line panasonic pt51hx42
  • 4,234 Answers
This is a convergence problem. Either there are bad connections on the convergence ICs or the ICs have failed. Try resoldering the pins on the ICs first. If that fails to resolve the problem, replace them, These ICs are large black ICs attached to a heatsink and are most likely marked STKxxx.
Dan
Posted on May 27, 2008
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
2000 PANASONIC TV WITH RIGHT SIDE OF PICTURE THE GREEN AND RED COLORS ARE ABOUT A 1/4" OFF FROM EACH OTHER
trysetting the convergence on the tv itself,if that doesnt work you have a bad convergence amp maybe just 1 of them,you have 2 1 for greenand red 1 for green and blue,hope that helps.
Jan 17, 2013 | Panasonic Televison & Video
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
Our Panasonic DVD-RV32 player plays movies in blk & white even if the movie is a color movie....
this is a cableing issiue. I assume you are playing it through a SVHS cord. check to see which pins may be bent. If it is true and none of the pins are bent then you simply need a new cable.
wikipedia talks about these color and non color pins http://en.wikipedia.org/wiki/S-Video
If you are not using SVHS cables and instead are using the RGB or red green and blue RCA connectors then you may have them on the wrong color on either the DVD or the TV get a light to be certain the color you were trying to line up was the right one.
You may have a bad cable here as well. on the back of the unit it doesn't say RGB it says component Pb Pr and Y but just look at the colors of the RCA jacks. Side note here you can use a different cord to test them out, even one of the red, white and yellow cables, Just make sure that the jack goes green to green and so on you don't have to have a green cable in between it, it is helpful but not necessary.
also for reference here is the manual http://www.panasonic.com/consumer_electronics/live_manuals/media/pa029/pkg/manual/PA029_02.html
Mar 25, 2011 | Panasonic DVD-RV32 DVD Player
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Televison & Video
Loss of color - all green
yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Sep 28, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
