Question about American Standard 40 G Natural Gas Water Heater
How do you check the condition of the annode tube in a hot water heater?
  • 494 Answers
You'll have to disconnect the water lines from the top to pull the rod up out from within the tank. If you don't have enough clearance above the tank, you'll have to drain the tank, remove the venting and tilt it or lay it down to remove it. The sacrificial rods usually go bad prematurely on well water systems with hard water and causes a sulfur stench in your water. Here's a quick test to try before you do this: Go to the nearest faucet to the water heater and fill a glass full of cold water and another glass full of hot water and smell them. If the hot water is the only glass that smells like rotten eggs, it's most likely coming from your water heater due to your anode rod. Douglas
Posted on Oct 04, 2010
Why does my hot water go hot and cold on my gas hot water service
When water feels cold at tap, check water heater TP valve and drain valve to see if water is hot at top and bottom of heater
Maybe you have bad single-handle faucet cartridge
http://waterheatertimer.org/Crossover.html
Another possible cause is bad dip tube
http://waterheatertimer.org/Water-heater-dip-tube.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 14, 2015 | Water Water Heaters
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
Nov 25, 2012 | Rheem Water Heaters
Hot water heater pilot is off. It's not gas,
You have tank-type gas water heater:
Open following link to watch thermocouple replacement.
Make sure new thermocouple sits into pilot flame. Instructions for relighting water heater are usually printed on side of tank.
http://www.youtube.com/watch?v=v0aBPsNg6vo
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 29, 2011 | Whirlpool Water Heaters
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
Where is anode location on a 100 gallon gas commercial water heater, model number G100-250?
There should be a hex bolt on the top of the water heater. Unscrew the bolt, the annode is attached to the bolt. The annode will be almost as long as the tank itself, so you should alow for vertical clearance.
Jan 26, 2011 | Rheem Water Heaters
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
I have a 80 gallon Ge smartwater hot water heater model # SE80T .Can a burned out heating element in the water heater cause a circuit breaker to overheat? Thanks
Normally no, but for a circuit breaker to activate, there has to be excessive current draw somewhere. Is the circuit breaker exclusive to the water heater? If it is then the heating element may have shoirted internaly. Fit a new element and restest. Don't forget to check the condition of your sacrifical annode too.
Mar 19, 2010 | Water Heaters
Rheem 50 gallon gas water heater less than one year old runs out of hot water almost immediately. They changed the thermostat and it worked for a few weeks then it stopped again. Any ideas?
it could also be the dip tube. this is a tube that is installed at the time the unit is made.it is a plastic tube that is on the cold intake side of the hot water heater.it may have fallen inside the unit or may not be in the unit at all check to see if there is a plastic tube this will help the heater stay hotter for a longer period of time. good luck with your project.
Sep 29, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
American Standard 40 G Natural Gas Water Heater Logo
242 people viewed this question
Top American Standard Water Heaters Experts
jdthefixer
Steven House
Don Eagan
Are you an American Standard Water Heater Expert? Answer questions, earn points and help others
