My emachine wont boot it gos to salect safe mode our normal and wen u click one it shuts down and gos back to the select screen again
  • 42 Answers
Bad news. Probably your hard drive has crapped out.
If you plan to replace the drive get a Seagate brand. They cost a little more than the Western Digital, but they last alot longer.
Posted on Oct 04, 2010
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
Computer screen goes black and stays black unless in safe mode.
Hi, you are lucky you can access safe mode. now in safe mode, go to device manager by right clicking on my computer icon and selecting manage. then select device manager. select the VGA from the list by the right and right click then select uninstall. restart system , it will boot into normal mode
Oct 15, 2012 | E-Machines eMachines Desktop PC
My hp pavilion dv6000 is stuck on configuration 3/3 0% and keeps shutting on n off
Turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see the SAFE MODE Option. Select the Safe Mode option and see if your machine completes the boot cycle. If it does, do a normal shut down and restart. When it restarts, you want to let it try to boot back up as it normally does. It still might try to do the configuration stuff again, so be patient and let it do it. If it gets stuck and starts shutting off and on as before, turn it off again and boot back into safe mode again.
Once in safe mode click Start/Programs/Accessories/System Tools/System Restore and select a date that is prior to the date when you first started having problems.
Don't worry,. System Restore does not delete any of your data, documents, music, pictures or videos. On the other hand, System Recovery DELETES EVERYTHING and sets your system back to how it was when you purchased it.
Mar 21, 2012 | HP Computers & Internet
COMPUTER WAS TURNED OFF IMPROPERLY. TURN-ON WAS IN SAFE MODE NOW EVERYTHING IS LARGER AND BLURRED
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
always click APPLY after making any changes
don
Feb 02, 2011 | Computers & Internet
How do i get e machines out of safe mode so i can reboot the computer?
If you are in safe mode, you should be able to shut down or restart the computer the same way you would in standard mode. Click the start button and select shut down or restart, and let it boot up normally. If you do not have the start button, you can try holding down control-alt-delete and selecting shut down from the menu. If all else fails you can hold down the power button on the computer for about ten seconds and the computer should power off, then you can turn it back on.
Jul 21, 2010 | E-Machines eMachines Desktop PC
Safe mode
Get windows 7, or downgrade to xp. lol kidding. During the start up, i beleve its either f11 or f12 press them it should bring you to a boot screen. follow option. or you can use the compaqs built in recovery system. reinstall your system. vista has a option to save its old files for transfer.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
Wont load passed windows xp screen
Try holding down the "F-8" key when the emachines logo appears, see if you get a prompt for "safe mode". If you can get the system up and running in safe mode, shut it back down from the start menu. That should rewrite the boot sector and may clear the problem.
May 10, 2009 | Computers & Internet
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
Mouse Cursor Frozen
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Jun 13, 2008 | E-Machines eMachines Desktop PC
Safe mode business
safe mode automatically comes up when you didn't shut down properly. Just select boot as normal or last known good configuration then you are good to go.
uninstall any new hardware or software you have recently installed to cause the problem in the first place. If you haven't installed anything then windows should just start normally.
good luck
smeags.
Jan 22, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
