Question about RCA eMusic MP3 Player
Formatie mi reproductor RCA TH1100A y cuando lo enciendo no reconoce la musica.....que debo hacer
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: problema con mi reproductor
www.usasupport.philips.com - available in espanol as well
Download Device Manager
click "Repair" first, then "Update"
Posted on Jul 05, 2008
SOURCE: MI MP3 ES NUEVO Y LA COMPUTADORA NO LO RECONOCE
dale click al icono mi pc y ahi debe de estar
Posted on Oct 02, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: la musica se corre
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Posted on May 24, 2008
SOURCE: cuando prendo el reproductor se apaga y lo prendo
Descarga el firmware de la pàgina de soporte de philips y actualìzalo. Eso deberìa reiniciarlo a los valores de fàbrica. Posiblemente pierdas los datos que tengas en la memoria del reproductor.
Posted on Nov 04, 2009
Como desbloquear regiones al blu ray
Hola soy de M?xico y tambi?n tuve el mismo problema mucho tiempo hasta que encontr? la soluci?n y aqu? te dejo paso a paso como hacerlo ;)
PASO A PASO: 1. Asegurate de que no hay ning?n disco en la bandeja.
2. Apaga el reproductor y vuelve a encenderlo (Esto es necesario para limpiar-arrancar el firmware)
3. Espera hasta que la p?gina del men? principal aparece y el reproductor ya no haga nada.
4. Pulsa el bot?n de expulsi?n para abrir la bandeja.
5. Pulsa el bot?n de expulsi?n para cerrar la bandeja.
6. Espera a que el reproductor busque un disco y tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda pulsa el boton STOP e Introduce 76884 en el teclado num?rico.(NO APARECE NADA CUANDO APRIETAS 'STOP', SOLO PRESIONA LOS NUMEROS ENSEGUIDA)
7. El c?digo de regi?n "4" debe aparecer en la esquina superior de la pantalla y en ese instante pulsa "9" para hacer la regi?n free.
8. Apaga y enciende de nuevo el reproductor.
9. Disfruta de tus pel?culas :D :D :D
NOTA: MI REPRODUCTOR CUANDO LO HICE REGION FREE DEJO DE LEER LOS BLU RAY REGION 'A', POR LO QUE PARA QUE LOS LEA LO QUE HAGO ES VOLVER EL REPRODUCTOR A REGION 4 SIGUIENDO LOS MISMOS PASOS SOLO QUE CUANDO EL APARECE EL NUMERO (AHORA 9) EN LA ESQUINA PRESIONO 4 Y LISTO, AS? QUE SOLO LO PONGO FREE (9) CUANDO VOY A VER LOS DVD'S QUE SON DE OTRA REGION. SUERTE.
Apr 23, 2013 | Samsung BD-E5900 Smart-3D Blu-ray Player
Region code
Hola soy de Mexico y tambien tuve el mismo problema mucho tiempo hasta que encontre la solucion y aqui te dejo paso a paso como hacerlo ;)
PASO A PASO: 1. Asegurate de que no hay ningun disco en la bandeja.
3. Espera hasta que la pagina del menu principal aparece y el reproductor ya no haga nada.
4. Pulsa el boton de expulsion para abrir la bandeja.
5. Pulsa el boton de expulsion para cerrar la bandeja.
6. Espera a que el reproductor busque un disco y tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda pulsa el boton STOP e Introduce 76884 en el teclado numerico.(NO APARECE NADA CUANDO APRIETAS 'STOP', SOLO PRESIONA LOS NUMEROS ENSEGUIDA)
7. El codigo de region "4" debe aparecer en la esquina superior de la pantalla y en ese instante pulsa "9" para hacer la region free.
9. Disfruta de tus peliculas :D :D :D
Mar 20, 2013 | Samsung BD-E5900 Smart-3D Blu-ray Player
Mi receptor optimus cuando enciende aparece power off y se apaga en pocos segundos
tengo un problema con mi stav-3770 y cuando lo enciendo me dice power off que debo hacer en ese caso ??
Jan 08, 2013 | Optimus STAV-3770 Receiver
Hello, recently purchased a Samsung BD-E5900, would it be possible to make it a region free player?
Sep 26, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
How to unlock Samsung BD-E5900
Hola soy de Mexico y tambien tuve el mismo problema mucho tiempo hasta que encontre la solucien y aqui te dejo paso a paso como hacerlo ;)
Jun 04, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
I have a samsung bde 5900 bluray player. Can someone help me unlock the region code?
NOTA: MI REPRODUCTOR CUANDO LO HICE REGION FREE DEJO DE LEER LOS BLU RAY REGION 'A', POR LO QUE PARA QUE LOS LEA LO QUE HAGO ES VOLVER EL REPRODUCTOR A REGION 4 SIGUIENDO LOS MISMOS PASOS SOLO QUE CUANDO EL APARECE EL NUMERO (AHORA 9) EN LA ESQUINA PRESIONO 4 Y LISTO, AS? QUE SOLO LO PONGO FREE (9) CUANDO VOY A VER LOS DVD'S QUE SON DE OTRA REGION. SUERTE..
May 28, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
COMO DESBLOQUEAR LA CASETERA DEL DVD SONY DVP-SR320
prendo el dvd y cuando quiero sacar la bandeja me sale bloqueado que puedo hacer grasias
Apr 30, 2012 | Sony Televison & Video
No me Funciona El compresor ni El Abanico del aire de El Que esta en la maquina de Cuando lo enciendo
Tengo una cosola Trans de consola de 240000 BTU cuando me la istalaron no funcionaba movieron el abanico y funciono.. aparentamente es el abanico. Actualmente esta funcionando. Que debo hacer.
Aug 20, 2010 | Heating & Cooling
Formatie mi mp3 RCA modelo RD2022 sin querer y ahora no reproduce la musica, al prenderlo dice que no tiene archivos pero en la pc si aparecen.
hola, a mi me pasaba lo mismo y sabes que hice? la formatee de nuevo y asi quiso funcionar, espero servrte de ayuda, nos vemos ^_^
Jun 01, 2010 | RCA Audio Players & Recorders
RCA eMusic MP3 Player Logo
206 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
