Question about Fisher and Paykel IWL12 Top Load Washer
My washing machine keeps coming up with error 130 and wont go past this. can you let me know what this means.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now error code 130 is called SINGLE ROTOR POSITION SENSOR ERROR.This means the rotor sensor which is attached to the motor is faulty or the wiring to it is faulty or the control module is faulty.Unfortunately to test the rotor sensor you need an RPS TESTER.I can help you test the wiring to the rotor sensor but unless you have an RPS tester I can not help you test the rotor sensor.Please reply and let me know how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Posted on Oct 04, 2010
Error code 130
IF a Fisher and Paykel, see this link:
http://ths.gardenweb.com/discussions/2427379/fisher-and-paykel-gwl11-error-code-130
You need to list brand (if not also model number) when you post white goods questions. Codes are specific to a manufacturer.
Mar 04, 2015 | Washing Machines
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
Fisher and Paykel MW 512 AU is not running. The first and the last lights(long wash and spin leds) on the displays stays ON in red and keeps on beeping. I appreciate any help in resolving this issue
This(130) is the only code that comes close to that,
There is no code for 129.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 26, 2012 | Fisher and Paykel Washing Machines
Hi I have an approx 8 yr old F & P Intuitive Eco Washing Machine and I'm getting a 136 error message every few wash cycles. (well I've had it twice in about 8 washes) What does this...
Hi - check out this post - Code 130 - 136 all mean the same its a communication error between the sensors & the controller.
By mattnewmanha on Jun 16, 2011
I have a F&P MW512 top loader. It has developed a code 130. I have been told this is a faulty RPS. is this something I can fix at home? is there a bypass? how do I access and inspect the part?
Jun 19, 2011 | Fisher and Paykel (IWL12)
My fisher & paykel 1w812 keeps coming up with a 130 fault code , any ideas
The 130 code means you have a Single Rotor Position Sensor Error.
Nov 20, 2010 | Washing Machines
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
CODE 130
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 26, 2009 | Washing Machines
Error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint wt741 f11 what does this mean
Hotpoint Error Codes.
Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
# F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
Dec 26, 2008 | Washing Machines
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel IWL12 Top Load Washer Logo
156 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
