Question about Cosco Deluxe Comfort Ride 01-834 Stroller
How to extend the handle? It is actually hard for me to walk with the handle too low. How can I fix it?
How can I extend my C partition to remove its low disk space problem?
The partitions D,E and F may system partitions for tools like system restore and diagnostics. I would suggest removing some stuff from C:, if that is not an option you could consider a hard drive upgrade.
Oct 17, 2014 | Computers & Internet
Bluetooth connectivity issues
My router extender did that once. A simple powered down and restarted fixed it. I hate to sound like Comcast which always tells you to do that but it's worth a try with wifi and bluetooth. Also obvious but check the battery, when it gets low enough the signal gets weak before it actually stops. Cellular telephones do the same thing. A low battery can affect signal strength.
Mar 16, 2014 | Motorola Radio Communications
Dell studio low memory
Low memory problems could be low virtual (hard disk) memory.
Hard disk maintenance will free up hard disk memory space.
Hard disk maintenance should be carried once a month to make your computer run efficiently.
This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Jan 04, 2013 | Dell Computers & Internet
Brand new Huskie 450e used for two days and the throttle is now broken. The actual trigger itself feels like it isn't attached to anything anymore. Is it an easy fix?
In the 400 series of Huskies I have fixed, the handle comes apart with several screws. Sounds like the simple problem might be in the handle/trigger assembly. The more complex problem is if the throttle linkage rod popped out of the throttle. The outside trigger interacts with a black plastic insert and spring that provides pressure outward to keep the throttle low. This assembly connects to a thin metal rod that looks like the path a drunk would take doing a sobriety test after too many martinis. The rod goes into the housing and connects into a hole in the throttle assembly, then is locked in place with a plastic piece that slides down to keep the rod from falling out. In order to see this area, the cover needs to come off. I'll be honest. The last one I had, the rod fell out of both ends. It took me two days of pondering, playing around, cursing, getting up and walking away, then coming back to finally figure out where the ends went. The blue plastic piece had slid down, covering the hole, so I was at a loss as to where it attached to the throttle. NOTE: When removing the handle, try real hard to keep it together until all screws are removed. THEN VERY CAREFULLY begin to take it apart, looking in from the top of the handle. You might get one good glimpse of how the parts fit together before they fall apart on you. Husky does have a good website for exploded view diagrams, but sometimes they leave a little to be desired for 2-Dimensional art vs. 3-D Reality. Good luck.
Sep 13, 2011 | Husqvarna 450 e-series 18" Chain Saw
Grohe shower valve installed in shower stall, one handle to turn on/off and adjust temperature, why would the water continue to run when the handle is turned off?
hard water build up, foreign matter or a defective cartridge are the most common causes of this...if you would like to try and fix it yourself just text me back w/the model # or a pic and i'll walk you through it. its pretty easy even for a novice:)
Aug 01, 2011 | Home
What make of walking foot would fit my Elna su air electronic sewing machine, thankyou
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
Jun 25, 2011 | Elna 2007 Mechanical Sewing Machine
I have a 15 inch electric trimmer. It can't stop running, i know that it's because of the constant connection in the electric wiring, how do i properly fix it. I just want to see the actual picture of...
Actual pictures of the inside wiring of these is hard to come by on the internet. Just locating a manual for this model is an extended job with limited results. Try just inspecting the trigger switch wiring and clean the contacts on the switch with some electric cleaner (available at Radio Shack). Try to do an overall inspection of the upper electrical system and look for anything unusual.
Oct 23, 2010 | Toro& Electric String Trimmer
Bought low flow 1.6 litre American standard toilet problem I am having is it makes this clinging noise constantly and when taking off the tank lid you can see that is filling up a slight amount
Serval reasons: (1) noise from handle chain being metal-consider switching to lighter plastic type. (2) The rubber flap which lifts up when handle is pushed down and seals "when handle is let go" to allow water to fill in take maybe worn to the point of needing replacement-Go to any Lowe's/HomeDepot and they will walk you through replacement process of just removing old one and putting ends in place over hooks to install new one. Takes me 1 minute to do. (3) Adjust the water cut-off valve that supplies water to tank so it can feel up rapidly by just turning the value. If value is hard to turn try using some oil or WD-40 on it. Remember that one way opens to allow quicker fill up and better flush and other way just turns water to toilet off. If now of these things work then just give me a yell and I can advise further.
Oct 06, 2010 | American Standard Home
Cosco Deluxe Comfort Ride 01-834 Stroller Logo
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
thegtw
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
