Connection not encrypted - Computers & Internet
  • 550 Answers
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Click Here for step by step instructions
Posted on Oct 04, 2010
Can't connect to wifi
Try turning off all encryption in the wireless router, delete the SSID's wireless profile in your computer, then connect to the SSID with no encryption. Windows should warn you there is no encryption, and it may limit your connection speed to 54Mbps (802.11n requires WPA2/AES encryption).
But if it then connects OK like that, you know the problem is/was an encryption mismatch.
In that case, switch the wireless router back to WPA2-Personal or WPA2-PSK with AES encryption, delete the newly-created wireless profile for your wireless router's SSID in your computer again, and connect to your WiFi with encryption, being careful to enter the WPA2 passphrase (8 to 63 characters) correctly when prompted.
Feb 11, 2014 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
The wireless network connection will not connect to shared modem. Enter the same and correct security key but still will not connect?
One thing to try is disable encryption on the router temporarily where it does not require a passphrase. Depending on how old the wireless card is, it may not be capable of the encryption level set at the router (i.e. some cards cannot handle WPA encryption. You could try it with no encryption to start with and then set it to just WEP. It is not the most secure encryption but will do.
Jun 30, 2011 | Computers & Internet
Cannot connect to Internet Error code 220602
Hello there!
There are a couple possible options to fix your problem that may work:
  • Temporarily disabling WEP encryption on the router.
  • Set up another internet connection profile on the Wii (w/o encryption key)
  • Select the User Agreement on the Wii.
  • Re-set the WEP encryption key on the router.
  • Switch back to the internet connection profile on the Wii (w/encryption).
I would try all of these and hopefully your problems will not persist. Good luck!
Jun 17, 2011 | Nintendo Wii Console
What does wep mean in nintendo wi-fi conection
WEP is a type of encryption that can be put on your wifi connection. You would use a WEP encryption key if that is the type of encryption your router supports. You will have to check your routers settings to see what type of encryption you are using to connection your DS to wifi and to get your encryption key, which is like a password to your wifi.
Apr 29, 2011 | Nintendo DS Lite
I set the router from wap security to wep and i cant connect to it now.
The WEP encryption key is in the router's wireless settings and changing this encryption will affect your wireless connection.
You must also configure the computer's wireless card settings with this WEP encryption otherwise the wireless router will not allow the computer to connect to the wireless router.
I suggest you use WPA or WPA2 encryption, this is a later and stronger encryption method than WEP encryption.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 06, 2011 | Belkin Basic Wireless Router
I changed from 64 bit to 128 bit back to 64 bit in 1 hr. It was an accident, and now my laptops will not recognize my router. My cable company has tried everything over the phone.We have changed the...
When you changed the WEP encryption from 64 bit to a stronger 128 bit encryption the encryption code gets changed and when you changes it back to 64 bit the new 64 bit encryption code will be different to the old 64 bit encryption code, that is why your laptops cannot connect to the router. The laptop wireless card needs to be configured with the new 64 bit encryption code before it can connect to the wireless router.
I suggest you configure the wireless router with WPA or WPA2 encryption, this is a much stronger encryption method than the old WEP encryption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Sep 12, 2010 | Computers & Internet
Wpa encryption for wireless g adapter
This is a known issue . A WPA encryption does not work for G adapters to N routers. Try to reduce the encryption to WEP and check . Im sure that will work.
Sep 06, 2009 | D-Link Computers & Internet
2nd laptop will not connect to internet
I'm assuming that your 2nd laptop is wireless? Does your router have encryption? If it has, then you need to get the encryption key from one of the working computers. Access the linksys interface from one of the working computers. Usually this is done by going to http://192.168.1.1 (leave username blank, password is "admin"). Go to Wireless> Wireless Security. Is encryption selected? If yes, get encryption key #1 and use it on the non-working laptop to connect to the router. If encryption is not enabled, go to the steps below.
On the 2nd laptop, click on the wireless icon at the bottom right part of your screen. Look for the linksys router from one of the available wireless networks, click connect and enter in the encryption key when it asks for it (not case-sensitive. Usually it's 10 or 24 digits). If encryption is not enabled, it will not ask for the encryption keys when you hit connect. See what happens.
Jul 05, 2009 | Linksys Wireless-G WRT54GS Router...
What is WEP and WPA encryption
WEP is like a clear connection with no encryption only to get this connection you need to enter key number and password.
WPA is more like encrypted connection and to that also you shall enter key number and password.
In today's wireliss connection speed there's no differences and you better use WEP since they got less connectivity problems
Nov 19, 2008 | Computers & Internet
CWA-854 as repeater
I couldn't manage to get the CWA-854 to work in repeater mode with WEP encryption enabled, but it is possible to use MAC Access Control even in repeater mode. Just put the CWA-854 in Access Point (AP) mode, add the MAC addresses you wish to allow in the Access Control tab and selecting Allow Listed from the pull-down menu, and then go back to the repeater configuration you posted. In this way, you may not have encryption, but you can still block others from connecting to your wireless network.
Jan 13, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
