Question about Element Electronics ELCHW261 26 in. TV
Element 42LE45Q tv on, blue light on no picture what can the problem be? we can hear it but not see the picture
Element tv wont turn on red light is on but wont power up
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Mar 31, 2015 | Element Electronics Televison & Video
I have a 32" element tv model number Eldfw322 and usually the blue element screen turns on and goes to whatever I have it on but now the blue screen is there for a split moment and cuts out. I can still...
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 11, 2014 | Televison & Video
No sound problem
Either wired incorrectly or is a settings issue.
Aug 08, 2014 | Element Electronics Televison & Video
Our element Tv has blue light on but no picture or sound
Probably power supply failure. The blue light merely indicates power is getting to your TV.
May 26, 2014 | Televison & Video
Blue blinking light. can hear the tv but no picture
Heat issue, what is the brand and the model number please?
Nov 08, 2012 | Hitachi Televison & Video
I have an Element 32" flat screen tv and when I
Possible there is fault on the motherboard as the processor seems to swtich on but there is no drive from the mother board. Unless a proper voltage check is done the voltage to the drivers cannot be confirmed.
Nov 04, 2011 | Element ELC-HS321 32 in. LCD TV
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
Element elchs321----tv cuts off on its own. when tv is plugged up, the light at the bottom is red and you can hear a crackle, the light turns blue but no picture or sound. Help
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors. That crackling sound is the capacitors burning out.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 15, 2010 | Element ELC-HS321 32 in. LCD TV
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Element Electronics ELCHW261 26 in. TV Logo
303 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
