Question about Harman Kardon HK19.5 Computer Speakers
My speakers will not turn on, the power cable is in a power strip but still no power, what can I do?
  • 734 Answers
My guess is that the smaller wires in the back of the speakers have been damaged by a short during movement or other handling.
That's the only answer you give me with your info
REPOST
I have XP...etc...changed operating systems....didn't check the wall plug....Help us out here!!!! So we can help you
Posted on Oct 04, 2010
Tip
How to Wire a Flat Panel Television with no wires showing
  1. Place all the components, TV, speakers, etc. where you want them. Don't worry yet about how to wire them.
  2. You may want to turn all equipment sideways on the shelves so you can get to the connections in the back.
  3. Plug in all the power cords into a power strip, but don't turn on the strip until you are all done.
  4. Learn to differentiate audio and video. Video connections are often yellow, audio connections are often Red and White, but newer systems can have more varieties. You'll need to make sure the color you are plugging in is the same for both ends of the cable.
  5. Start wiring all the cables. You can see that all the cables and connections are clearly labeled and color-coded.
  6. Use the concept of 'signal path' to connect the necessary OUT's to IN's. Cables are needed to give the signal a path to travel from one piece of equipment to another. OUT of the antenna, IN to the VCR. OUTof the DVD player, IN to the TV. OUT of the receiver, IN to the speakers etc.
  7. Follow this guideline when hooking up equipment:
    1. The wall (cable/antennae/satelite)
    2. Things that send out signals (TiVo/cable box/set-top box)
    3. Things that record (VCR/DVD Recorder/Computer)
    4. Things that play only (VCR/DVD/Receiver)
    5. Things that display (TV/Monitor)
  8. Turn everything on. If necessary, switch channels and settings to match the labels on the connections you've just made. Enjoy!
on Dec 03, 2009 | Televison & Video
Need the pin positions of the wire harness
  • red is switched ignition 12 volts (only on with cars running)
  • yellow is constant power 12volts ( have voltage at all time even when car off this wire allows you to save station and clock so you are not allway resting the clock and stations)
  • black is ground ( connected to the frame of car or a good metal part that is connected the frame of car with out a good ground the circuit will not be completed and the radio will not power up )
  • white drive side front (+) speaker wire
  • white/black strip driver side front (-) speaker wire
  • gray passanger front (+) speaker wire
  • gray/black strip passanger front (-) speaker wire
  • green driver side rear (+) speaker wire
  • green driver side rear (-) speaker wire
  • purple passanger rear (+) speaker wire
  • purple/black strip passanger rear (-) speaker wire
  • blue or blue/white strip wire is (remote amp turn on or power antenna )
  • orange wire is (dimmer for light in car )99% of all cars these days don't use this wire
have any question email me at radiorepair@windowtintingin239.com
Oct 27, 2013 | BOSS AUDIO SYSTEMS 636CA
HP dv6704nr power button doesn't work but quickplay/dvd start laptop, completely turns off if screen is beyond the cut off point no matter if it is in POST or in windows, and speaker doesn't w
i would take the button bar of and check to see if the cable is off to one side its a flat ribbon cable sounds like it is a little sideways that will make that happen there is a little clip be gentle undo it a little bit and straighten it out
Feb 25, 2013 | HP Pavilion dv6704nr Notebook
Hum in my eons
The hum is because your connecting your speakers to the same power strip or extension cord, try connecting each one from different power source. I had the same problem with mine.
Feb 18, 2013 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
My problem is that i don't know how to turn off my bose companion 2 II, so i've been unplugging it from electricity whenever i don't use it, but i think that's wrong. Thanks to anyone who can help me.
No power switch on this model. It goes into standby mode to conserve power. If you want you can buy a power strip or usb power strip (so you can turn it off via your pc) and then power that off with the speakers plugged in.
Hope this helps
Jul 28, 2009 | Bose Companion II Computer Speakers
Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Jan 23, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon HK19.5 Computer Speakers Logo
29 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
