Question about HP Pavilion dv6000t Notebook
Every time i turn it on my laptop is no screen and restarting...
  • 2,567 Answers
Motherboard is defective & needs to be replaced with a new one.
You can find a replacement motherboard by searching on e-bay.com with the motherboard's model number. This could be found under the RAM.
Posted on Oct 09, 2010
Its a toshiba satellite m200 wel i turn it on it starts then comes up in a black screen with start nomaly or restart in windows an other suff etc on screen try all of this but laptop just shuts down after...
first it may be cpu cooler problem some times it may be a OS problem too
patiently check the time intervals how much time your system is on stand by. try to run your system in safe mode and check again once to enter safe mode
restart
and press f8
select safe mode
check and post me
Apr 20, 2011 | Computers & Internet
I have a laptop toshiba l500d series. My question is the screen turns green only the black parts all the time. What would be causing this problem. Thanks
Hi, the screen may turn green when the Graphic Driver is corrupted. Please re-install the Graphic Driver in the Computer. The Graphic Driver can be downloaded from the Laptop Manufacturer website. Restart the computer after installing the Graphic Driver. If the issue persists, restart the computer and try pressing F2 Key to enter BIOS (Basic Input Output System) setup, then check if the screen displays green color. If the screen displays green color in BIOS setup then the issue is related to Hardware of either display or graphic card of the Laptop. In this case, please contact the manufacturer of the Laptop to initiate the service under Warranty. If the laptop is not under Warranty then service charges may apply.
Apr 17, 2011 | Computers & Internet
When I turn my laptop on it goes into safe mode and sometimes the screen doesn't come on when it is turned on. There are times when I have been on my laptop it will for no reason restart itself. Today...
Looks like some thing is going wrong there, Can you please try disk check and let us know what happens after that
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Jan 13, 2011 | Acer Aspire 5602WLMI Notebook
Computer restarts every time screensaver comes on
try to turn off the laptop, remove the cables and battery, then press and hold the power button for 8 secs. Reinsert the cables and battery and turn on the pc. Observe if the screen saver works...
Aug 03, 2010 | Toshiba Satellite P105-S6197 Laptop
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
Dell inspiron 1429 would not stop restarting
just read the error on that blue screen...Its a dump error....then tell me....
ashishcgaikwad@hotmail.com or on 9665071117
Aug 27, 2009 | Dell Inspiron 1420 Notebook
Presario v2000
When you first turn the laptop on, wait for the Compaq screen to go then press F8 a few times.
A Windows Start screen will appear
Select "Last Known Good Configuration" and press enter twice.
Apr 13, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion dv6000t Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
