Question about Rinnai Webstone The isolator EXP tankless water heater Service Valves WRIK
I have a Rinnai Continuum Model 2532 natural gas tankless water heater in my home. It takes about 45 - 60 seconds for the water to get hot at the faucet which is closes to the heater. This thing is suppose to provide hot water instantaneously on demand. What could the problem be?
    Problem Solver:
  • 17 Answers
Clean filter on the cold side coming in and clean or replace the aerator at the sink, rinnai works on water flow, common problem if your water hardness to high or if you have iron in your water
Posted on Oct 23, 2010
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
I have bought a used Rinnai R94LS natural gas tankless water heater and need to know which thermostat to buy for it? I have bought a used Rinnai R94LS natural gas tankless water heater and need to know...
Plumbcentre have a parts desk for gas appliances.
most appliances are available to view in an exploded view with clear identification of parts.
However when it comes to gas, I strongly advise on using a GASSAFE engineer
Nov 18, 2014 | Water Heaters
I have a wall mounted tankless water heater for
It's scaled
Do you have a softener? Water must be 15 GRS/PPM or less in iron and calcium. Hot spots in unit are boiling water and are causing the noises.
Descale and flush unit following Rinnai Specs and check water hardness for compliance with Rinnai standards because too hard an inlet water will VOID the Heat Exchanger Warranty (10 year).
Oct 19, 2014 | Water Heaters
We have a bosch tankless water heater in a 1600 sq ft home...it works great except in one faucet (the spare bathroom sink)...sometimes the hot water comes out, sometimes it doesnt, sometimes it takes...
Since you have hot water at all the other fixtures, the problem lies in the sink, not the water heater. It could be that the sink is farther away from the water heater than the other fixtures. It would take longer to get hot water.
Aug 29, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
What pump should be used to flush the Rinnai Continuum 2532 water heater?
any utility pump with garden hose connections or a sump pump set up with hose connections. Allow the unit to flush for at least 45min and be sure to clean the inlet screen when done.
Mar 17, 2010 | Water Heaters
How to install rinnai 2532 Continuum Individual temperature control
if you mean additional remotes then go to rinnai.com and enter your model number. go to owners manual and it gives step by step instructions
Jan 10, 2010 | Rinnai Webstone The isolator EXP tankless...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Rinnai Webstone The isolator EXP  tankless water heater Service Valves WRIK Logo
996 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
