Question about Ovens
Therws a red ,black,white,copper wires coming out the back of the oven how do i wire them to the outlet?
  • Ovens Master
  • 43,501 Answers
Here is a tip that will help you with wiring that oven.
Oven Cord and Wiring Oven for 3 Wire or 4 Wire
heatman101
Posted on Oct 04, 2010
I am hooking up a double oven to my house the wires coming from my house is black black and copper both blacks are hot the wires coming from the double oven is black red white and copper How do I hoo
The blacks are hots which wilkl give you 220 volts the bare one is the neutral conductor so the hook up the stove black to one lead red to the other white to bare.
Nov 06, 2012 | Ovens
I have white, black and ground out of wall, i have red, black, white and ground from oven, how do i connect
Unfortunately you can't. Your wall outlet is a 110V circuit (B-110V; W- common) and your oven needs 220V circuit to operate. Red - 110V; Black - 110V; White - Common.
You will need to installed a 220V, 30 AMP (10-3/w ground) homerun from your circuit breaker panel to the oven
Jun 21, 2011 | Whirlpool RBS305PR Electric Single Oven
I am instling a whirlpool accubake double oven, my house wiring is 3 wire (black,black,coper) the instructions say coonect red to red, black to black and white and neutral to coper. If neither of my house...
Doesn't matter....hook one black to the black and the other black to the red....copper to the green,white, and/or ground...whatever you have...
then you are good to go...
heatman101
Apr 30, 2011 | Whirlpool Ovens
WHERE DOES WHITE WIRE ON WALL OVEN GO FOR HOOK UP - WE HAVE RED, BLACK, WHITE & COPPER
white wire goes in the middle copper goes to ground or chassis
Oct 04, 2010 | Whirlpool Ovens
I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
My Maytag Oven has 3 wires one red, one black & one white and then a copper wire. Will my oven model M5530DDs work with 220VAC? If so how can Identify which wire is which in electric terms?
red and black wires are the two "hot" power wires, the white is your "N" neutral connection and the bare goes to the appliance metel case as safety ground
Oct 02, 2009 | Maytag 30 in. Electric Single Wall Oven...
I wired up the the Fridgedaire wall oven and it worked for two days and then just shut off. It has a green, white, black and red. The white and green are taped together coming out of the oven. The...
the unit is 240 volts not 120 volts/its ok to have the wht and green tied together so long as it comes directly from the house main panel/new law in some places require them to be separate/wht=Neutral/Green=safety grd to case...now how many watts does this unit draw? 2/12 wires sound awful small for the input current/sounds like you need to upgrade to atleast 2#6 wires for power/1#8 for neutral and atleast a #10 for safety ground
Sep 30, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Dec 26, 2008 | GE Profile JTP56 Electric Double Oven
Moffat oven
U need to open/unscrew back and look at bottom connections to the left ( looking from the back) Earth green and yellow- Blue is neutral and Brown is live you probably need electrical female spade connectors for your end of the 'hard' wire !!
Jun 07, 2008 | Jenn-Air JJW8330D Electric Single Oven
KitchenAid Architect Series KEMC308KSS
the black to white 120 the red to white 120 the red to black 240 the bare copper can tie to the white neutral and ground will work as the same any other reading then there is a voltage problem in the house
Apr 12, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
