Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Once i plug my external in, the little white light on for about 3 - 5 minutes, and than it's start blinks but not open.
  • 42 Answers
For one - it is Western Digital.
It is probably toast.
If you plan on getting a new one, get a Seagate.
They are far superior in quality.
Posted on Oct 04, 2010
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
I just tried to try my NES (wichs hadn't been use for a long time) again. When i plugged everything and turned the NES on, the light start blinking. Then, I put a game in it and opened the tv on channel 3....
You can try to change the input to Video instead of channel 3 since you're using a RCA (Red, Yellow and White) cable.
Thanks for using Fixya.
Jan 31, 2011 | Nintendo NES Console
My book essential has worked for several months now til now.... the white light is just blinking and my computer doesntg seem to recognize it anymore what should i do?
From the user manual (click here) on page 4, the slow blinking means that the drive is in standby mode.
The user manual does not explain how to get the drive out of standby mode, but you may want to try the procedure for powering off the drive that is on page 34 that say to press the power button on the back of the unit and wait for the LEDs to turn off.
If the unit does not power-off on its own within a few minutes of pressing the power button, the next thing to do is the following:
Shut down your computer with the drive still connected and powered-up. Once the computer is completely powered-down (no lights on or noise coming from the computer, unplug the power cord of the external USB hard drive and wait a minute. After you've waited a minute with the external USB hard drive unplugged from power, plug the power cord back in to the external USB hard drive Make sure the USB cable from the drive to the computer is properly connected. Power-up your computer using the power button on the computer and let the computer boot as usual. Once the computer has booted, check whether the external USB hard drive is now available.
Happy New Year and Thanks for using FixYa
Dec 31, 2010 | Western Digital My Book Essential 1TB...
My 1993 Toyota Tercel does not start when key is turned. New battery, all fuses checked and fine. When the doors get opened, hazard lights start blinking for 15 blinks, then pause, then 15 blinks. This...
This sounds like a starter disable feature of a car alarm. Somewhere under the dash you are going to find a box with the start wires running to it. The start wire is black with a white stripe and is thick, about a 12 gauge wire. It will come from the ignition switch and run into a relay or box. It could be installed anywhere as it is aftermarket. Once you find it, you can reconnect both ends of the starter wire and you can start it with the key. I would disconnect the power to the alarm or your lights are going to flash at random. The factory alarm (just in case it is the issue, but that isn't likely) is located behind the radio and ashtray.
Dec 14, 2010 | Toyota Tercel Cars & Trucks
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Maxtor 750GB External Drive Blinking White Light
If you hear a click-click sound it means that your drive's mechanics ia failing. BAD NEWS !!
Jul 06, 2009 | Maxtor Shared Storage II N01R010 1 TB USB...
Camera software corrupted??
I had the same problem with my flip mino HD. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Apr 13, 2009 | Pure Digital Flip Video Ultra Camcorder
DROPPED and BEEPING
Remove and reattach the HDD from Casing once and check it. If this wont work HDD may damaged. Consult MAXTOR customer service.
Mar 25, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Green light blinking on back of my system unit but there is no power
I had this problem and i tried everything to make it work. Now all i do is put a hairdryer at the back whilst the computer is plugged in until the light stops flashing then switch on as normal. I also noticed that when the air is warm i do not have to use the hairdryer hopes this helps.
Aug 31, 2008 | Computers & Internet
1994 gmc safari
Sounds like your Passlock security system went into the tamper mode. If your dashboard security light blinks when the ignition is turned on, your Passlock security system is disabling the injector module, preventing the car from start. Try this:
1- turn the ignition on and just touch the starter, without getting the motor to fire, then leave the ignition in the "on" position. The security light will blink for about 10 minutes. When the light stops blinking, turn the ignition off and leave off for 3 minutes.
2-repeat the step #1, 3 or 4 times. You will know that is fixed when you turn the ignition on and the security light does not blink, then the car will start. Make sure to stay inside the car when you're doing this, as opening the doors will trip the security tamper mode on again. Once the tamper mode is off, the car starts and opening the doors will not trip the Passlock tamper mode.
Aug 06, 2008 | 1994 GMC Safari
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
94 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
