Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
I have a Maxtor 3100 100gb external HD and tried to backup my computer and it would only backup 4gb. I got a message that if the HD is formatted in FAT32 it would only backup 4gb. I need to backup about 35gb. How do I format the Maxtor so I can back up the 35gb. Thanks
  • 734 Answers
1. Please connect you external HD to your computer
2. Fat32 can only handle a limited amount of data
3.Go to the Control Panel
4. Open up Administrative Management
5. Open Computer Management
6. Open Disk Management
7. In the denter panel you will see your Maxtor expressed
8. Right click on the drive
9. Click format
10. Choose NTFS
if not given the coice, it will usually format to NTFS anyway, but get smart, explore Disk Management and make sure
11. I'm giving a general scenario across 3 different Windows OS Sytems
12. When you tell us your exact Operating System, we can be more helpful
TheSelkie
Posted on Oct 04, 2010
I have a Maxtor onetouch 4. I want to use it as an external hard drive. Windows explorer recognizes it but when I try to copy files to it, it says the drive is write protected. I down loaded the Maxtor...
That's because the software it comes with unlocks the drive to do backups. You should be able to format the drive in windows and then it should work fine for your purposes.
Right Click the Drive, Select Format, give it a volume name if you want and select quick format. Leave everything else default.
Comment back if you have any questions
Sep 11, 2011 | Maxtor OneTouch III Mini Edition 120GB...
I'm having problems with my buffalo mini station 1tb HD-PXTU2. It cannot copy files that are 4gb and higher. After trying to copy it, an error message will appear andf state that the disc has no spac left...
From My Computer the External Hard Drive can be reformatted.
I beleive the format is called TFMS, this allows a larger than 4Gb single entry to be inputted. It is probably formatted for FAT32 which is limited to 4Gb units
Nov 14, 2010 | Computers & Internet
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Maxtor One Touch III 160GB is not accessible - corrupted or ...
i had the same problem, i have removed the hdd cover and manually rotated the disc few times, it worked for 20-30 minutes, but it was enough to recover my data
Aug 20, 2009 | Maxtor OneTouch III (T01E160) 160 GB USB...
Tring to back up pc to elements 1 tb external hd
Fat32 simply means that your hard drive can only read files up to 4GB, format your external harddrive using file system NTFS then try to back up all your files again. Hope it helps you...
Jun 22, 2009 | Western Digital My Book Home Edition 500...
I recently purchased and downloaded Maxtor One Touch4Plus Backup faile and I get a message Of Parameter is incorrect to edit my settings backup log states "Destination is not accessible" All file "not...
please try reformat your maxtor external driver. use default allocation size wait for a minute after finish unplug the maxtor external, restart your pc and plug in your external see what happen and try again to backup your data from pc
Jan 29, 2009 | Computers & Internet
External disk drive full when i try a operator initiated backup
Before runnning the backup please go ahead and run the check disk once..
chkdsk /f/r use this command on the command prompt
Nov 11, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Delete info from an external hard drive?
run diskmgmt.msc delete. then create then format .. also theres a tool called Wipedisk from www.thefreecountry.com/security/securedelete.shtml
Jul 21, 2008 | Maxtor Hard Drive
Maxtor mini iii 120 gb HD
Uninstall the back up software, and choose another or reinstall it.
Oct 17, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
99 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
