Question about Sony NWZ-E436F MP3 Player
Possible had 12 voltz of dc current attatched to stereo wires. the mp3 player stopped and got real warm in the back. now it will not start back up. Did i fry it or just temp. problem? tried the reset button already
  • Sony Master
  • 32,281 Answers
I would say yes, you have fried your MP3 player. These MP3 payers operate on 5 volts and 12 volts would damage your player beyond repair.
Posted on Oct 04, 2010
Vr3 vrvd630 wiring
This page might help: http://www.jeeppatriot.com/forum/showthread.php?t=7275
And this page will provide you with several pages to visit: https://www.google.com/search?hl=en&source=hp&q=+94+Jeep+Vr3+vrvd630+wiring+diagram&gbv=2&oq=+94+Jeep+Vr3+vrvd630+wiring+diagram&gs_l=heirloom-hp.12...2109.46750.0.48484.29.5.0.24.1.0.94.407.5.5.0....0...1ac.1.34.heirloom-hp..25.4.329.QRoy2DxAm28
Sep 05, 2014 | VR3 CD PLAYER MP3 WMA RDS CAR STEREO...
Want to know if i can connect mp3 player/ipod to so the hi fif will act as a dock
You can buy a cable that will connect the output of your mp3 device to the input jack of your stereo at most electronic stores. Make sure its stereo. Very simple to do.
Jun 27, 2012 | Audio Players & Recorders
How do i power it on without it being hooked up in car
if you have a 12 volts ac/dc adapter you can hook the 3 wires Black for negative, Red and yellow for positive and the stereo will turn on.
Jul 22, 2011 | Power Acoustik PTID-5300 Car DVD Player
I hook up a amp with red and black wire from the car stereo, then the stereo stopped turning on, why?
You probably blew a fuse. The power wires for a stereo can not handle the current an amp needs. An amp has to get it's power directly off the battery. Get an amp kit that has the power wire, ground wire, turn on lead, and fuse w/fuse holder. fuse the power no less than 12" from the battery.
Apr 19, 2011 | Boss MP3-3030R CD Player
Stereo wiring on mk4 golf r32? Fitted new stereo bit radio isn't working I Need to know what colour wire to connect to the power supply for the amplified ariel?
12 volt accessory or same wire that goes to red wire on stereo or cigarette lighter.
OR
What is the current draw on amplified aerial ? or are you talking bout electric aerial(up and down automatically ?) If current draw is really low like 500 milliamp or so then hook her up to blue wire (remote output) on back of stereo but REMEMBER this is LOW current and only meant to switch on amps and raise electric aerials etc.If you think amp on aerial is too much for it then run the rem wire to a 12 volt relay and wire it so that when rem triggers and closes the gate will be connecting an accessory wire OR perm 12v wire to aerial power . That way aerial ONLY turns on(POWERS UP) when stereo is on as opposed to other way where aerial will be powered up every time car ign or acc is turned on regardless of whether the stereo is on or not.
Jun 18, 2010 | Car Audio & Video
Car lost presets on ignition
Hi and welcome to FixYa,
Let's start with the basics:
  • yellow wire to an always on B+12;
  • red to ACC terminal of IGN switch;
  • black to ground;
The yellow/always on is responsible for keeping the memory, that is the stations that you have had memorized/selected. The always on is directly connected to the battery's + terminal.
Would appreciate any updates. Good luck and thank you for using FixYa.
Feb 13, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Wanting to install a mp6212 cd player in my tool box at work
for proper operation, you will need 12V.
Some vehicles wont start unless there aer 8V.
Minimally 8VDC, but 12V recommended for proper internal amplifier operation. Purchase a used PC Power supply, and wire directly to the hard drive power pug. Inverters are also available.
BTW Amps are a measure of AC Current, not DC. DC is measured in Volts.
An Electrical appliance rated to work on AC will not work with DC, and vice versa.
You will need an invertor of some type to change the signal and wavelength.
Dec 26, 2008 | Jensen VM9510 Car DVD Player
Aux wire?
Your query > ..."wire...to hook...mp3 player ...RCA RS2044 stereo..."
You need to connect the headset out of your MP3 player using a special cable to theInterfaces/Ports: AUX-in of the RCA RS2044.
One of the many technical name for the special cable is RCA Male Stereo to male baby phone stereo, the common name is MP3 to RCA and it is similar to the function and look of a Cygnett Groove Transit - MP3 Phone to R...
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 29, 2007 | RCA RS2044 Shelf System
Nothing from amp
The RCA "plugs" should be in an OUTPUT of the radio (sometimes they are INPUTS, like for an MP3 player..). Go to Sears or somewhere similar and buy an inexpensive Multimeter. Set it to DC volts and place the black lead on the GND termunal of the amp. With the red lead on the BAT terminal you should read roughly 12 volts always. With the car running and radio on, place the red on the REM terminal and again you should see 12 volts. If not it's the wiring. If the voltage is 12 on both then the amp is likely damaged.
Sep 01, 2007 | Kenwood KAC-7202 Car Audio Amplifier
IRiver H10
Require more history 1/condition of H10 battery B4 this problem (blown Charger Fuse) occurred 2/perhaps battery condition severly depleted creating high current draw upon initial charge attempt 3/not certain if an circuit protection fuse exists in H10 4/Chk charger wiring for shorts bare contacts etc.
Nov 27, 2006 | iRiver H10 MP3 Player
Sony NWZ-E436F MP3 Player Logo
179 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
