Question about Maytag Neptune MAH5500B Front Load Washer
I have mold on the rubber gasket between the door and the drum. I have tried to wash it with bleach but it does not come off. Is there a way to clean it or does it need to be replaced. Is it possible to replace it?
    Sergeant:
    Champion:
  • 351 Answers
Maytag has a kit to fix that i would call maytag
Posted on Oct 04, 2010
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
How do I get the mold off the rubber piece on the door can I use terpintine?
Turpitine may damage the seal.Vinegar should safely and effictivly clean mold
Aug 12, 2011 | Frigidaire Washing Machines
Black scum forming forming on rubber seal on inside of washing machine door
  • 1 Put on rubber gloves and safety glasses before commencing the cleaning process.
  • 2 Lay an old towel or drop cloth on the floor under the front of the washer to prevent floor damage as you clean.
  • 3 Fill a plastic cup with bleach and dip a tooth brush into the bleach.
  • 4 Remove the toothbrush and scrub the washing machine gasket with it to remove the black mold from it. Hold the gasket open with the fingers of your other hand so that you can clean the center grooves of the gasket where the most mold is likely to grow.
  • 5 Rinse the toothbrush in the cup of bleach and continue cleaning until you have removed the mold from the entire gasket.
  • 6 Wipe the gasket with a paper towel to remove excess bleach residue and any remaining mold.
  • Jul 02, 2011 | Zanussi Washing Machines
    Mold on rubber gasket
    The door seal need to be pulled almost inside out to be a able to thoroughly clean it. I usually use a 50-50 mix of bleach water but other cleaning products like oxyclean may work better. After cleaning run a load with no clothes in it to remove any residue. Now if the mold has gotten deep into the rubber and still looks blackish after cleaning it will get moldy real soon and replacement will be the only solution. The key is from day one to leave the door open as you do and also wipe the door seal with a towel after each use. Not to defend frigidaire but most of the other brands have the same issues, some worse. If you need to replace the door seal or if the wire ring pops off when cleaning here is a link that should help http://appliancehelponline.com/washerdoorseal.html
    Jul 13, 2010 | Frigidaire ATF6000ES Front Load Washer
    Clothes stained and mold growing on rubber ring inside, constant odor despite using monthly washer clean tablets, leaving door open and draining water out of washer
    Use a mixture of bleach and water in a spray bottle to kill the mold. Leave door open after washing. Also spray your drum and rinse unloaded to kill the mold on the inner drum.
    Jan 06, 2010 | LG WM2016C
    I have mold growing where the rubber seal is around the door. I have a ine year old and I am worried about washing his clothing.
    A nicely moist area,
    ...could try to kill all the mold with dilute chlorox (put some in a spray bottle--can also use on feet after the gym to prevent contamination from athlete's foot/feet)(or the shower mold killers which usually just have chlorox [sodium hypochlorite or similar]); then in future leave the door ajar when not in use so the area can dry (assume front loading), and if it is the large gasket style that still leaves a moist area behind itself--could put a wedge like a popcicle stick or few to allow air behind the gasket.
    ...any mold that is visible and therefor in contact with the clothes going in and out, should be easily removed...there should not be any mold in the washing compartment as the bleach and hot water used for whites would always kill the mold; so the only contact point is at the exterior (cleanable) when removing finished clothes.
    ..likely there is plenty of mold exposure in his environment beyond this----this is nothing like the problem with flood contaminated walls/floors and unseen mold that could spew forth significant amounts of spore load.
    Aug 09, 2009 | Washing Machines
    Musty smell in washer and clothes.water remains in rubber gasket
    Two thing that you might try: Add two or three cups of bleach and have the machine run a cycle (with no clothes!!!). Second, always leave the door open after use to let it air out. Also, it wouldn't hurt to use straight bleach as a wipe to the entire rubber tub seal.
    Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
    Mold on gasket
    The mold is common with the front loaders all you can do about the mold is wipe out the water that is in the gasket after a wash and leave the door open. DO NOT TRY TO CLEAN WITH BLEACH. The bleach will make the gasket weak and cause it to rip and then cause a leak.
    Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
    The solution? Plain old bleach.
    Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
    Keep door open after each wash to ensure that it dries out properly.
    d
    Oct 12, 2008 | Whirlpool Washing Machines
    I have a Neptune 2000 stackable washer. It seems that water is always remaining in the drum after a cycle, and water is sitting in the rubber gasket at the door. I am getting mold on the gasket and odor...
    All washers still have some water in them at the end of the cycle. If you wipe the door boot down with a mild bleach and water solution this will keep it from getting mold. If you don't do a bleach load on a regular basis I would run a hot wash with 1/2 cup bleach and 1/2 cup powder cascade with no clothes once a month to keep the machine cleaned out. I also always leave my door unlatched when not in use.
    Apr 23, 2008 | Washing Machines
    Maytag Neptune MAH5500B Front Load Washer Logo
    99 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
