I own thompson TG78T2; but have to run extension phone line into office(bedroom) where computer is located to connect my modem to line.... is there any other options i have....someone suggested dongle wirless adaptor 2.0 usb...so how does this work when im over 18metres from main phone jack.... or am i just better of with powerline kit that turns electrical outlet into network connection. if i was to use dongle/ wireless adaptor - will this affect my speeds of upload/downloading and keeping conencted. also i dont understand how the dongle kot comes with 5 metre usb cord - what is that for????\r\nmany thans for your help
  • 537 Answers
SOURCE: D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Posted on Oct 31, 2007
osborne382
  • 306 Answers
SOURCE: how to get a third computer to work on my wireless network
is the adapter connected to the router? are you using wep? is the firewall disabled?
Posted on Nov 11, 2007
SOURCE: problems setting up Belkin wireless G+ mimo modem router/usb network adapter
I keep losing connection to internet. I have comcast rca modem with belkin wireless g router. HELP???
Posted on Dec 09, 2007
IB4G2008
  • 3587 Answers
SOURCE: Suddenly lost internet connection on 2Wire DSL modem
hmmm...only thing that makes sense here is that your dSL is unhappy...did you check that phone line into the modem? that's what the internet light means when it's out, actually..if its not the line, then it's the modem..
not much else that is off on this.
check your computer warranty here 4 FREE
Posted on Feb 28, 2008
watz up
  • 6 Answers
SOURCE: siemens gigaset se587 wlan dsl
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Posted on Sep 19, 2008
Printer trying to receive a fax, but it doesn't print. Does there need to be a separate phone jack into the printer itself, and not just the computer?
Hey!A fax line needs to be connected in the fax machine yes!It sound like u got a dial up modem yes?Plug the phone line into the line jack on the machine,get another cord and plug it in the extension jack on the fax and to your modem!!Hope it helps!!Good Luck!
Nov 05, 2010 | Canon MX300 Office All-In-One Printer
Connection to phone line
do you see two phone jacks in your modem? you probably already know w/c jack is for the incoming (the one where you connect the phone line when you try to surf). so all you need is to get a spare telephone line/cord. connect that to the other jack in your modem and from there to your phone.
direct route from phone line to modem to phone unit. no extensions and no splitters.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Intercom / page problem with AT&T phones model 944 and 955
Do you have DSL on this line? Make sure you have filters on the lines going to the phones or take the line coming out of your DSL modem and split it to the phones.
Also, try unplugging your fax, computer modem or credit card machine and test the intercom. Sharing one line for several devices can make the intercom unhappy.
Feb 21, 2010 | AT&T 944 Four Line Intercom Phone
Can't connect AirPlus Extreme G+ wireless router and modem
assuming you have adsl/broadband coming down your phone line, you plugn the phone lead into the Thompson. If this is working you simply connect one of the LAN sockets on the Thompson to the Internet socket on the back of the Airplus.
You will need to make sure they dont both have the same IP address otherwise they won't work.
The IP address is the numbers you log into them with, eg 192.168.1.1
If they're both hte same, you'll need to log into one and change the address in the advanced settings area.
Jan 03, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a Arris Modem from time warner cable, no i
do you have dsl filter where the phone line comes out of the wall and goes into the Router.
https://en.wikipedia.org/wiki/DSL_filter
Mar 26, 2017 | 2wire (1000-000057-000) Modem
I have three questions regarding the Avaya One-X Quick Connect G11 PSTN Gateway. 1. Can it be programmed to ring all phones and if noone answers then go to extension 200 voicemail? 2. Can you get rid of...
1. Can it be programmed to ring2.gif all phones and if noone answers then go to extension 200 voicemail?
Yes, you need to browse to the gateways IP and look at the destination of the lines. If a single extension is the destination, you need to make a group, put all the phones in it, and then point the lines to that group.
2. Can you get rid of the dial 9 to get an outside line and just grab available line when handset is picked up?
No, unfortunately you can not.
3.How do you eliminate noise and echo in the background when on a call?Also has some bleeding over, someone else in the office could hear meon the phone when they were on the phone.
Make sure the gateway is grounded to a good ground. if the problem persists, you can try to upgrade the gateway and phones.
Oct 09, 2009 | Avaya ONE-X QUICK OFFICE EDITION TRUNK...
Have two computers but only one will get internet access
The tech is right, you can only have 1 modem on your residential line. The 2-wire router/modem should
have 4 ports in back to share with other computers AND a wireless signal too. You can run an
ethernet cable to your bedroom or get an adapter (either USB or PCI card) to connect to your router and
share the modem. If you go wireless, the 2-wire router is by default an encrypted signal. The password
is on the sticker, usually all numbers. Look at manual for changing configuration.
Jul 09, 2009 | Gateway Wireless-B Router (wbr-100)
Trying to connect 4 dsl routers to 48 port switch
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Feb 24, 2009 | 3Com 2250 Plus (3C16476CS) 48-Port...
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
