Question about Whirlpool Washing Machines
How Do I access the door handle mechanism on a Whirlpool WF810w (NZ model) washing machine, there are no screws to undo?
  • akeeban Oct 04, 2010
    Looking to repair the handle on the door frame. Have removed door from machine, but unable to separate the two parts that enclose the handle and the door glass!
    Many Thanks
    Regards
  • 15,935 Answers
What is the exact model number please?
Thanks!!
Posted on Oct 04, 2010
  • Whirlpool Master
  • 713 Answers
HI just read your posting.Now are you trying to repair the handle on the door itself or the interlock on the frame of the machine?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
  • luisa_sgro Oct 04, 2010
    Hi just read your posting.Now, by memory , the 2 halves are clipped together.Last time I replaced the handle on this model I used a small screw driver to separate the 2 halves. Have you got a new handle for the door assembly? If you have then you will not get confused on how to put it back together once the 2 halves are separated.Check the door closely and you should see the 2 halves clip together.Please reply on whether you have a new handle assembly for your machine and I will check to see if my memory of your door is correct.Looking forward to your reply.
Washer/dryer has completed two cycles and the door won't open
The door lock mechanism is stuck. You will need to get access to the back of the machine in order to undo the screws holding the top of the machine on. Make sure the machine is unplugged from the pains supply, there are wires attached to the switch and they may be live. Remove the top of the machine and reach down inside to where lock is (near door handle on front), push on the back of the lock/switch and it should release. If the problem re-occurs then the lock/switch will need to be replaced.
May 03, 2016 | Hotpoint Ariston Aquarius WD420 Front Load...
How do I remove the doorknob to possibly oil it?
it would depend on the door knob construction and what was stiff inside it.
The problem could be part of the handle or part of the lock mechanism.
For a typical indoor door lever handle, undo the screws on the face plate and take the handle off and oil as appropriate. You may have oil handles on both sides of the door.
For a rotating door knob handle there is generally a single screw on the underside of the knob
For a lock mechanism, you could just spray oil inside the mortise moving part (you wouldn't have to dismantle anything to do this!).
However to dismantle it, you'll need to remove handles on both sides of the door, remove the square bar that slots between both handles and remove the lock mechanism (you may have to remove locating screws that exist on the mortise face. If lock mechanism is user serviceable then there will be screws to undo to allow it to be dismantled. If none exist then it is probably worth buying a new one.
Oct 16, 2014 | Hardware & Accessories
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
Door lock mechanism stuck in locked position with the door open. Can not close door. How can I unlock it?
sounds as tho you will need a new interlock unlocking it will not cure the problem. Easiest way to it is to undo the wire round the door rubber pull off the door rubber from front of machine undo door lock screws at front then you should be able to clearly see the lock dont take any wires off till you are absolutely certain of the exact place they came from.
Mar 31, 2010 | Whirlpool GHW9400 Front Load Washer
How to change a gmc yukon driver side exterior door handle. door handle has come lose
take the door pannel off there will be a 10mm nut holding it on also there is a 10mm bolt on the side of the door you must remove also. after just pop the handle out disconect lock rods and its off
Jan 02, 2010 | GMC Yukon Denali Cars & Trucks
Broken door handle Hotpoint WD860
Managed to work it out, you have to slide the outer door case away from the handle locking mechanism, slide left and move away (after undoing the 6 screws on the inside) :-)
Dec 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Change grip/handle on a indesit washing machine w105tx
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Dec 02, 2008 | Indesit WA 125 Front Load Washer
My door handle on my zanussi fls 1183w washing machine has broken and ive bought a new handle but dont know how to get old one out can you help please
normally on zanussi doors they have 5 or 6 screws around the edge on the inside of the door if you try to undo them and take apart the door the handle should come out be carefull not to drop the glass
Nov 11, 2008 | Zanussi Washing Machines
Indesit washing machine wd10uk
Hi, you will have to remove the door seal fastener first, the just push the door seal inside the drum.
Mar 30, 2008 | Indesit WA 115 Front Load Washer
WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Dec 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
