Question about Lightwave Tech (200.0074)
MY OPTICAL WIRELESS MOUSE LIGHTWAVE MOUSE IS NOT WORKING ON WINDOW HOME ADDTITION BOGHT LAST MONTH IT WORKS FEW DAYS WITH LIGHT ON THEN SECOND TIME NO LIGHT AND NOT WORKING EVEN WITH WIRE
Mouse not working
Posted on Nov 14, 2010
I've had this wireless mouse for 3 months (microsoft wireless mobile mouse 4000). it just stopped working. the battery is fresh (the red light is still on) and the transmitter is still firmly in the usb...
When you replace the Battery on a Wireless Mouse you have to link the Mouse again with your USB receiver. There should be a Button on the bottom of the Mouse that could be marked, Reset, or Link or something similar. Just turn on your Mouse and hold this Button for a few second until the USB receiver finds the signal.
Jan 05, 2011 | Microsoft Wireless Optical Notebook Mouse...
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
Wireless optical mouse (DELL) doesnt work on my windows 7 system
mcdevito75 here, The optical mouse should have instructions, or you can type in search from home page up-date drivers.
Jun 25, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I have a clight problem with my mouse and keyboard set i got it from a friend of the families becasue it was getting interferance when they tried to use it (can't change the freqency it uses) anyway long...
Wireless connections are not reliable. One solution is to buy a wired keyboard and a wired mouse. Depending on where you live, they can be obtained for $10 and last for years.
May 01, 2017 | Microsoft Wireless Optical Mouse
Optical light on Mouse not working
maybe the battery?
follow the steps below to troubleshoot the mouse
Wireless mouse does not respond (generic instructions)
Try to Resynchronize your device with the receiver(connector)
Follow these steps.:
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse at least 6 feet away.
1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
2. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
3. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 3 again.
For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
or
Try different port and restart your computer.
or
Reinsert the batteries or install fresh batteries
If you have the possibility check whether the problem is because of your computer or the device, try the mouse or the keyboard on a different computer.
Sep 06, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse Not Working in XP
the very first thing what u have to do is uninstall and reinstall the driver for the wireless mouse and then restart the computer and still if it doesnt work try it with some other computer which has xp sp3 and it it works with the other computer have the same windows os then uninstall and reinstall the wireless driver also,and if it doesnt work with the other computer also then replace the wireless mouse.but before that always check ur wireless connection with the wireles mouse and also check the lights on the mouse..and what u can do is call up dell and tell thatm to replace it for u or for complete solution u can call up cyyberdefender.com for premium tech support.......take care ...
Jan 23, 2009 | Microsoft Wireless Optical Mouse
Mouse only works for a few seconds and then stops.
have you changed the batteries recently? Wireless mice seem to eat batteries faster. I have a Dell wireless mouse. It will work fine for months and then nothing. That's when I know to change out the batteries. If your batteries are fresh, make sure they are seated in their slots securely.
Dec 02, 2008 | Belkin F8E825 USB Mini Wireless Optical...
Wireless keyboard numbers on right not working and wireless mouse light not on
My Dell wireless keyboard doesn't work. I replaced the batteries in it and pressed the green button on the back of it then the button on the wireless thing plugged into the computer. That light blinks for a few seconds then stops but the keyboard still doesn't work. My wireless mouse works fine.
Oct 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Microsoft Natural Wireless Laser Mouse 6000 doesn't work
Hi
If you take the batteries out there is a screw in there. unscrew and open (not easy) with flat knife in the edges wiggling.
attach and touch all the inside wires. I have had the same problem and it is an internal connector problem. Opening and closing aint easy and will take a little patience but it will work.
Good luck
May 03, 2008 | Microsoft Wireless Optical Mouse
Computers & Internet Logo
518 people viewed this question
Top Lightwave Tech Computers & Internet Experts
David Payne
David Payne
Are you a Lightwave Tech Computer and Internet Expert? Answer questions, earn points and help others
