Question about Sharp AR-407 Copier
Sharp ar 336 How do I disconnect the personal counter what and where are the swithches. I have already unpluuged it. Thanks
  • 3 Answers
H3 01 on sharpcopy 407 what is the couse and solution
Posted on Dec 01, 2011
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
Dec 05, 2013 | Sharp AR-C160 Color Copier
Sharp AR-336 Copier u2-00 error
Check EEPROM for proper set-up
To prevent the erasure of counter data
and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
Dec 04, 2013 | Office Equipment & Supplies
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
Sharp copier ar-336 error h3-00
H3 00 Fusing section high temperature trouble
Detail: The fusing temperature exceeds 242°C.
(An input voltage of 0.27V or above is
detected.)
Cause: thermistor trouble
Control PWB trouble
Fusing section connector disconnection
AC power trouble
Check and remedy: Use DIAG (SIM5-2) to check the heater lamp
Blinking operation.
If the heater lamp blinks normally:
Check the thermistor and its harness.
Check the thermistor input circuit in the
control PWB.
If the heater lamp keep lighting:
Check the AC PWB and the lamp control
circuit in the control PWB.
Use DIAG (SIM14) to cancel the trouble
Feb 10, 2011 | Sharp AR-M237 Copier
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Jan 22, 2010 | Sharp AR-M237 Copier
How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
Aug 28, 2009 | Sharp AL 800 Copier
Sharp AR-C240p change yellow toner counter still say's 0
please dear your yellow toner is not original, so you change it or buy original thanks
Jul 30, 2009 | Sharp AR-C240P Printer
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-407 Copier Logo
105 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
