Question about Acer Aspire 5600 Series 5630-6951 Laptop
Web cam problem
When i click on to my web cam geting message camera not found. where has it gone. can this problem be resolved.
  • Anonymous May 31, 2008
    cam can't open
  • 121 Answers
1 - check for the webcam driver...sometime uninstalling and reinstalling the webcam driver gives a result in such situation.
2- check the integrity of your webcam connection via usb ports ; check usb ports too ; try other usb ports if possible.
Posted on May 27, 2008
I've gone through the neccessary steps to installing my webcam, but when I go to use the Webcam Companion, or even try to find a camera on skype it says that either the camera is being used by...
Try to disconnect your webcam then reinstall cd driver reset your PC. then connect again your webcam. testing and configure using skype messenger or yahoo messenger. driver of HP AU165AA Web Cam click this link : http://www.driverguide.com just sign up and join to download type HP AU165AA Web Cam and click search icon.
May 29, 2011 | HP AU165AA Webcam
Cant use webcam
Open messenger,click on messenger name top left.Then click on my web cam.When web cam screen opens click on file,then preferences,then camera source.Make sure camera source shows name of the web cam your using.If not select from drop down list.
Apr 26, 2011 | Yahoo Messenger
My web cam is working in xp but not getting installed in vista. what do i do?
Dear User,
Install driver software first from your disc of web cam, then restart your pc
then connect web cam, then follow procedure below,
1. Right click on my computer and select properties
2. click on device manager on left panel of system properties.
3. From list click on + sign of image device, right click on camera driver and click on update driver
4. In update select first option, let windows to find update from internet, windows will find
best driver available from PC it self or Internet (make sure ur pc connected to internet).
Hope fully this will resolve problem
Feb 27, 2010 | QPS QSIPBL2 Network Camera
My crystal eye web cam is completely gone from my computer.
ACER Aspire 5737Z – Acer Crystal Eye WebCam camera no found
I had the symptom where ‘no camera found’ and the device not showing in device manager (unless you expose hidden devices, but was visable via non present hardware (exposed via system variable
devmgr_show_nonpresent_devices=1)
Solution – Disable and Enable USB Controllers
1. From Device Manager
2. Right click and uninstall the Standard Enhanced the Universal Serial Bus controllers -> Standard Enhanced PCI to USB Host Controller – do this for both via right click - uninstall.
3. Right Click <YourSystemName> from the top of Device Manager, Click Scan for Hardware Changes.
4. Your Acer Crystal Webcam should now back under Imaging Devices, and working again!
5. Strange but seems to fix it, good luck!
I also pressed the top of the laptop screen to the left and right of the camera at around the same time. Not sure if something clicked back into place, either way above is a simple thing to try... Hope this helps.
Jan 22, 2010 | Acer Aspire 5610-4648 Notebook
INTEX IT-1301WC WEB CAMERA DRIVER CD LOST
1. Go to: http://www.intextechnologies.com/webpages/download-driver.aspx
2. Under the "Download Drivers" section, click "PC Web Cam".
3. Click on "Colledia 1300K (IT-1301WC)"
4. Click "Win XP/Vista". This will start the download of your web cam's drivers.
Jun 28, 2009 | Logitech QuickCam Messenger Web Camera
Web cam getting network error
goto yahoo messenger -> prefrences - > webcam -> camera source check if it found or not if not reinstall the camera driver hope it willl found and work
Oct 15, 2008 | Yahoo Messenger
Installing without cd
Yo may find your cam here and download the correct drivers of your cam. http://www.logitech.com/index.cfm/webcam_communications/webcams/&cl=sg,en
However, if you can not resolve then it is good to reply this message with the model of your webcam. the model it helps resolving the issues.
melnavz
Oct 02, 2008 | Logitech QuickCam Messenger Web Camera
Logitech Web cam Messenger
ok,
what you can do is uninstall your cam drivers and reinstall again, as soon as your computer recognizes the camera, try following the new device wizard and select install from a list of specific location. this will prompt you with a compatible driver for your cam and select that. then follow all the prompts and click finish. after installing it, restart your computer.
then try it now.
post if this resolved your issue.
Jan 28, 2008 | Logitech QuickCam Messenger Web Camera
Web cam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to  QuickCam Messenger Personal Web Camera  is unable to detect  . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
I recommend you to try below solution.
Please open below web link:
http://tinyurl.com/2dgvb8
This will open a new window, the page title as" Troubleshooting".
Please perform the steps that are mentioned in the web page. The steps are related to your issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Oct 18, 2007 | Logitech QuickCam Messenger Web Camera
Acer Aspire 5600 Series 5630-6951 Laptop Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
