Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Motor won't engage when release handle to vacuum.
  • 377 Answers
Please look at this URL for operating instructions, floor adjustment, etc.
http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
If you feel you are following the directions and still not getting the motor drive, check for broken belts and/or frozen beater brush. Will be happy to go further if this solution does not solve your problem. Paul
Posted on Oct 04, 2010
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Roller brush does not engage
. Turn unit on the side and inspect brush assembly for dirt, hair, etc. , also check the condition of drive belt , be sure that it is engaged with brush roller and turning freely. Also check the option of the'suction release' valve near handle which may free brush movement. good luck. a1fe9acb-d948-4a5d-a15d-619a901ba149.jpg 72bf93b5-160b-4ddd-8f56-3515fb5b8a7e.jpg 72bf93b5-160b-4ddd-8f56-3515fb5b8a7e.jpg
Jan 04, 2014 | Shark Navigator Bagless Upright Vacuum
Bissel cleaner won't stop spraying water
Remove the handle and check for continuous spray.
After handle is removed, check to make sure the valve is not stuck in the down position. If the valve is stuck in the down position, push on it manually to get it to come back up. If it is stuck you may need to get a new handle for your unit. This handle is for a variety of the ProHeat models http://www.bissell.com/parts/?sc=part&productid=2775&partid=4449&cid=ccsocial
Check to make sure it will properly fit your model if you need a new handle.
May 08, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Replace pump
Six (6) on board/top screws approx. Two (2) in front near nozzle area and four (4) under water resevoir tank. Engage handle release and lie handle down on floor and take out screws and save (of course) You will need to also unscrew clear water cap from top of on board unit and save and make certain you retain process to put back into position..(cap/spinner/small screen /pin up) Now you have access to the pump/motor, drive belts, etc. Unscrew appropriate screws and detach water lines and note replacement points. from pump near front right area of unit. Good luck!
Apr 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
While the windtunnel is upright the suction is awesome. When you lower it and engage the brushes is looses suction. It will not pickup anthing on the floor
check the brushroll if it spins freely, replace the belts 38528-034 and 38528-035. and make sure the tensioner for the V belt engages when you release the handle and pull the head back
Dec 30, 2009 | Hoover U8361-900 WindTunnel 2 Bagless...
Kenmore Beltless Vacuum brush will not spin. Everything else works.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
Jul 23, 2009 | Vacuums
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Pedal does not engage anymore
I have the same problem. You will need to replace the handle release pedal, part number 8174899, $7.99 plus tax & shipping. Check with Sears Parts. It's a single screw that holds it in place.
Jun 29, 2008 | Vacuums
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
44 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
