Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Have a Cushman lawn mower model No. 898807-8710 and can't find the part needed for it. The part no. is 889538. Where can I find this shaft or a replacement part?
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 138 Answers
SOURCE: Find whe the oil filter is located
verry carefully. seriously, though, on a briggs engine, it will be on the left side of the engine at the bottom rear - on a kohler it could be in the same position or the left side top rear - on a kawasaki it could be either - get an oil filter wrench and unscrew the filter counterclockwise [if the filter is horizontal, slip some rags under it, there will be a mess], make sure the rubber seal on the old filter does not stick to the engine, if it does, peel it off, put a light coat of oil on the rubber seal of the new filter and screw it on clockwise, tighten about 3/4 turn after contact with the base
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: Need image, assembled craftsman model 917.276813 lawn mower deck
http://afternoon-tea.bordadom.vu.cx/index.html italian wine bar
[url=http://afternoon-tea.bordadom.vu.cx/index.html]italian wine bar[/url]
<a href=http://afternoon-tea.bordadom.vu.cx/index.html>italian wine bar</a>
Posted on Aug 26, 2009
Dolfoff
  • 148 Answers
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 24 Answers
SOURCE: I have Craftsman LTX 1000
The deck belt is 144959 which is 1/2" X 95" and the drive belt is 140294 which 1/2' X 82". Sears Parts direct has these belts in stock. Here is a link to the parts diagrams
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917272480/0247/1509200?pathTaken=&prst=0&shdMod=917272480
Posted on Jun 13, 2011
The timming on the one piston and twoo velve victa 50 lawnmower.where the mark of a crank shaft and cam shaft must piont?
The timing mark on the camshaft and crankshaft must line up. There is a dot on the crankshaft and a line on the cam shaft. they need to be set in the gear where those two will meet.
Jan 10, 2015 | Garden
Will a shaft from a 14 yr old craftman lawn mower fit on a 2 year old craftman
need to have model numbers from both engines with spec numbers as well but most likely no
Jun 21, 2012 | Garden
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn mower sounds like it is running fast and vibrating.
Sounds like a bent shaft, or bent blade.
Also sounds like the part that holds the blade to the shaft is sheared, and allowing the motor to run faster than it would if it is turning the blade properly.
Hope this helped,
Please rate me
May 25, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Need a replacement splindle for Sears LT3000
The complete spindle is called a mandrel on sears site part number 192870 $47.24. You can also get the housing all by itself and reinstall the shaft and bearings into it part number 187281 $24.60. The shaft is what the blade attaches to and can be purchased separate part number 192872 $17.84. All these parts can be purchased at a local Lawn repair shop for less money just take in these part numbers or your model number with you.
Mar 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need to find mounting bolts, blade to shaft
Do you meanengine mounting bolts, blade boss, and 'Operator Presence Control' cable? If so, they are generic parts - not specific to your mower. I have no idea why you are having problems ordering them - they are consumable parts, and should be stock items for ant garden machinery repair outlet.
Aug 06, 2009 | Craftsman Garden
Which manufacturers make a lawn tractor that uses a drive shaft?
kubota does & i also think john deere does try them
Jun 23, 2009 | Garden
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
450 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
