HP dv5-1000us. as soon as you turn on the laptop, minding we just put in a new motherboard, the caps lock and scroll lock light flash.
  • 42 Answers
Does the system boot up properly and function normally?
If so don't worry about the flashing.
Some motherboards have a self check function that causes those lights to flash .
Posted on Oct 04, 2010
The screen will not power up on my hp pavilion dv7 4065dx
Count the blinks and pattern of the caps lock light flashing. They tell the technician what is going on with the system. If this is happening as soon as you press the power button you are probably having an issue with the Video Card, Memory or some other motherboard related issue.
Does the system seem like it is up and running? If not, it's definitely one of the three issues mentioned above.
Remove the Power Cord, Remove the Battery, Remove the Memory Cover on the bottom of the laptop, then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.The link below will gives you the blink code listing from hp website. When it opens up scroll down to to see what the blinking lights pattern means as to the cause of your system not booting.http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
Apr 18, 2012 | Computers & Internet
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
My HP Pavilion dv5 1125nr laptop won't boot up. The screen never lights up when the power is turned on, the little hard drive light next to the power light doesn't flash at all (normally it flashes...
check by removing the battery then put it back again power it on, or without battery power it on directly then check, if still the same problem, the fault is in the motherboard of the laptop, better take it the service center or consult some technician in your area
Aug 02, 2011 | HP Pavilion dv5-1125nr Notebook
As soon as you turn on the laptop, minding we just put in a new motherboard, the caps lock and scroll lock light flash.
on most Dell portables, that is indicative of a bad Modem attached to the Motherboard or a bad motherboard
Oct 04, 2010 | Computers & Internet
I have a dell inspiron 1521 . All three lock lights are flashing and then the systems shuts down . Turns back on and flashes then shuts back down repeating this process constantly. I have the original...
same problem i slove ... 1st of all remove ram and turn and wait 20 second .. return the ram on by one .... may b one ram has problem .. if same then open ur laptop remove battery cell for 1 min and keep laptop off .. after one min return cell and dont close laptop just check open is work then close .. if not change thek crystal wich is near the winbond ic... near the keyboard conector.. hope it will be okie .. Thanks
Sep 16, 2010 | Dell Inspiron 1521 Laptop
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
Blink: 3 - Caps Lock/Num Lock
Memory
Blink: 4 - Caps Lock/Num Lock
Graphics
Blink: 5 - Caps Lock/Num Lock
System board
Blink: 6 - Caps Lock/Num Lock
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
My Hp dv 4 1220 us laptop. The fan will come on
Try new memory (RAM) or if the device has two memory module install turn the deviice off take one module out turn on
If it does not work then
Turn the device off take the second module out replace with the first module
Turn the device on
Jan 06, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Inspiron 6400 doesn't start.
On Flash Flash indicates that no RAM memory is being detected. So remove both RAM modules, insert 1 at a 30 deg angle till the gold contacts cannot be seen, then lock it in place, and see if the RAM is detected. Test both modules in both slots, see if system will boot with at least one. If no change, try a new RAM module, if still no change, replace the motherboard
Jul 04, 2009 | Dell Inspiron 6400 Notebook
HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Feb 02, 2009 | HP Pavilion dv4000 Notebook
Open Questions:
Computers & Internet Logo
510 people viewed this question
David Payne
David Payne
