Question about Samsung Dryers
Dryer tumbler was turned by hand which was fallowed by a noise and know dryer will not run. All buttons seem to work but dryer just wont start.
    Brigadier General:
  • 4,088 Answers
Turn the dryer on, then check the air exhaust to see if it is blowing air. If it is, then remove a lower back panel to check if the drum belt has jumped off of the motor shaft and idler pulley. Hope this helps!
Posted on Oct 04, 2010
    Sergeant:
    Champion:
  • 351 Answers
Belt jump off
Whirlpool gas dryer Model GGW9200LW0. tumbler will not start everything functions as usual but the motor makes a humming noise and the tumbler will not turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Whirlpool GGW9200L Gas Dryer
My Maytag dryer model # LSG7804AAE is making a lot of noise when drying. It is squeaking and if I turn the tumbler by hand it seems very stiff and feels like it is rubbing against something. Thankyou.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 26, 2011 | Maytag Dryers
Model # 110.63012101 Won't start. Light comes on
heatman101
Oct 22, 2010 | Kenmore 64972 Electric Dryer
Model DVL223 GE dryer buzzes / hums when the start button is turned, but does not start or turn the tumbler tumbler moves freely by hand from inside
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 07, 2010 | GE DVL223EBWW Electric Dryer
Maytag DE303 Dryer
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Jul 24, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
DRYER RUNS ABOUT 15 MINUTES, HEAT WORKS,MAKES NOISE AND STOPS
heatman101
gdhi64
Feb 13, 2009 | Whirlpool LGR5636L Gas Dryer
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
Intermittent ignition
my dryer just stoped. when i press the start button it makes a noise and then theirs a small burnig smell if i turn the tumbler it works for awile then back to the dryer being stoped again.
Dec 09, 2007 | Whirlpool LGR8648 Gas Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
63 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
