Question about IBM ThinkPad T40 2373 Notebook
Tecra 8000 won't recognize battery
That's the problem. One day working fine, battery charging, next day can't
find battery. Thought it was battery, replaced with new battery. Charge light may stay on 2 minutes, but then go off, and little box that shows battery charge says N/A.
  • 3 more comments
  • jmoo369 May 27, 2008
    It's dead without the power cord.
    That computer is so old there's no warranty.
    And are you talking about asking Toshiba for technical support?
    So far I've tried all except replacing the cables. I really was hoping to find an answer here. I had done all this before I asked the question.
    Wrong choice of words. Not replacing. Checking.
    I think I've reached the point at which I need an actual person to look at this problem. I may just leave it as it is. I can get by with the power cord. Just a problem if the plug gets kicked in the middle of a job.
    But thank all you guys for helping.
  • IBM Master
  • 13,433 Answers
Most likely a fault in the battery connector or on the mainboard.
Check the connector pins on the laptop
Posted on May 27, 2008
  • 3 more comments
  • Ekse May 27, 2008
    You could try twisting the power pins a little bit, only a little so the battery goes in still, so the connection isn't loose. This might be tricky as if you twist it too much the connector wont fit anymore.
  • Ekse May 27, 2008
    so you have tryed another battery, so the fault isn't in the batterys its either on the power connector or somewhere else on the motherboard.
  • Ekse May 27, 2008
    what cables where you thinking about replaceing?
  • Ekse May 27, 2008
    The only solution for this is the power connector, if its something else thats wrong, It might not be worth the money.
    would need to diagnose and test the motherboard very carefully to find the fault, easyer to replace the mainboard but that cots..
  • Ekse May 27, 2008
    You may press the accept button on my solution if you are satifyed.
    Sergeant:
    Champion:
  • 230 Answers
There will be fault in the connections inside the laptop that connects the battery do check that
  • 2 more comments
  • balachander megavarnam
    balachander megavarnam May 27, 2008
    remove all the cables and replug them and try
    you need to replace the connector if the fault is in it..........better
    go for warranty if you have because repairing by own may void
    warranty............if you dont have warranty .......ask the technical
    support of your laptop itself this will help you
    thanks for using fixya
    please dont forget to rate the solution
    there is a technical support for ibm also i think
    Master:
  • 555 Answers
If you unplug your laptop from wall power, will it run on battery power?
  • Matt Jurach
    Matt Jurach May 27, 2008
    Or will it behave as though no battery is installed, and not power on?
Hello. At first, the indicator light that shows whether the battery is loading/getting empty etc. failed. As I thought it wasn`t important I continued using the laptop. Then the battery loading adapter...
Most probably this is caused by the battery charging circuit inside your laptop. It looks like it is not charging the battery. If this is the case you won't be able to fix it yourself. You and should send it for repair.
Feb 28, 2011 | Computers & Internet
How do I switch from battery to power on my Toshiba Tecra 8000?
Mama,
You do not have to switch from the battery to power as long as the powwr adapter is plugged intp the wall socket and the laptop. When the battery goes low it starts charging while running the laptop and when not charging it runs the laptop alone. I hope that relieves you of your worries?
Nov 05, 2009 | Toshiba Tecra 8000 Notebook
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
May 26, 2009 | Toshiba Tecra 8000 Notebook
When using ac adapter to my Tecra 8000 the power light is yellow
Try a new battery and if the new battery wont charge then its either going to be a bad ac adaptor or a bad motherboad. If the new battery charges then you'll know that the old battery went bad.
Mar 29, 2009 | Toshiba Tecra 8000 Notebook
Toshiba Tecra 8000 keeps switching itself off.
I'd suggest removing the battery. Most laptops can run directly off the AC adapter. If it will boot up OK without the bad battery, you can either leave it like that, or buy a new battery.
If it won't boot, then you have problems other than the battery.
Feb 08, 2009 | Toshiba Tecra 8000 Notebook
Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Nov 16, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Toshiba tecra 8000 boot problem
sounds like the batteries are incompatible..this is an important aspect
Oct 09, 2008 | Toshiba Computers & Internet
BATTERY PROBLEMS
you could try the battery in another laptop of same age to see if it is the battery itself, or check the laptop and see that the battery is getting any of its power to the motherboard.
May 27, 2008 | Toshiba Laptop Computer Battery PA2510,...
IBM ThinkPad T40 2373 Notebook Logo
46 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
