Question about Maytag Atlantis MAV6000 Top Load Washer
My Maytag 6000 Atlantis washing machine won't spin out all of the water and sometimes none of it. It does go through the spin cycle though. Sometimes I have to do the spin cycle again and it will either spin out the water or it won't. What could be wrong?
  • 18 Answers
SOURCE: maytag washing machine #mav6260aw
If you are a good DYI'er you can find the parts here http://www.repairclinic.com/0003.asp you'll need a couple of hours set aside and maybe a few beers for after. If you are not going to fix it yourself the labor costs and parts would come
to just about the price of a new one. Hope this helps.
Posted on Nov 11, 2007
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
  • 22 Answers
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
appldoctom
  • 311 Answers
SOURCE: Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Posted on Jan 03, 2009
  • 236 Answers
SOURCE: Maytag Atlantis screeches @ end of spin cycle,
may be something stuck in the drum or a segment raised on the motor. to test either remove the belt and spin the drum if no noise then the motor is faulty. if a noise then there may be a bra wire between the drum/tub.
Posted on Mar 16, 2009
Maytag atlantis washer mav6300aww drains water but does not spin
my maytag washer model #MAV6300AWW will not spin out during cycle but can turn it back to spin and will spin out
May 30, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV6000AWQ won't spin
my maytag atlantis does not spin fast enough to get all the water out.
Oct 28, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Mav6260 washer will not spin
the belts on these units will streach, and alot of the early unit had bad belts.
the unit should spin with or with out water in the spin cycle
also the thrust bearing on these units go bad often.
this is a magic chef washer with the maytag name on it.
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis 7600 spin cycle (top load)
the maytag runs in one direction for wash. it reverses to drain and spin - check for a broken or loose belt. maytags I have run into circa 1989 have two belts. as for the softener dispense, there may be a solenoid valve that is supposed to open. may be just a flapper type of valve. softener goes in by gravity feed.
Sep 04, 2007 | Maytag MAV7600 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
