Question about Mr. Heater Natural Gas Garage Heater - 45,000 BTU
What size propane tank do i need with a Mr. Heater 45,000?
    Problem Solver:
  • 12 Answers
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Posted on Oct 04, 2010
Testimonial: "Thanks very much for the help!"
WHAT SIZE PROPANE TANK DOES THE GLO WARM 630 NEED?
The tank size dosn't matter all you need is a feed line This looks like a spicific tank appalaction but just feed it remotely with a normal propane tank and a feed line and save your self the head ache as long as it dose what you want it to do ist cool
Mar 06, 2012 | Mr. Heater Thermocouple
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
Jan 30, 2011 | Mr. Heater Mr Heater Portable Buddy...
I have a natural gas heat star garage heater it will stat but it wont light
try jumping out the pressure switch see if it lights , or first unplug heater and replug in might reset or it could need a clean
Dec 11, 2010 | Mr. Heater HeatStar Radiant Tube Heater -...
I have an Enviro propane fireplace insert installed last year & it worked fine. The tank & regulator were changed because I got another gas supplier. For some reason now I have a low flame....
It sounds to me like you need to increse gas pressure. Most propane fired units need at least a 11 inch water column of pressure for proper operation. This relates closely 7.5 ounces. I would have regulator checked out by qualified service techs. Thank you
Nov 20, 2010 | Mr. Heater Mr Heater Portable Buddy...
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Mr. heater problems
defective venturi or cob webs in burner
Jan 17, 2009 | Mr. Heater Mr Heater Portable Buddy...
No propane comes thourgh pilot on mr buddy heater
If the pilot will not light get a q-tip and alcohol and remove the wire grill and be sure the cotton doesn't come off the end of the stick wet the cotton with the alcohol and twist it and push it down into the pilot tube 2 full inches. Let the alcohol soak for 30 seconds and while twisting pull the q-tip out. Try this until the pilot lights.
Jan 01, 2009 | Mr. Heater Mr Heater Portable Buddy...
Open Questions:
See all Mr. Heater Natural Gas Garage Heater - 45,000 BTU Questions
Mr. Heater Natural Gas Garage Heater - 45,000 BTU Logo
903 people viewed this question
Top Mr. Heater Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
