Question about GE 30" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel
Hi, I have a GE electrical self-cleaning 30" oven stove - model # GRCR3950RB-1 made in Canada. The inside glass pane of the door cracked during self-cleaning and I would like to change it. I cannot find any reference to that model on the web. I would like to know where I can order a replacement glass pane and what is the part number? I live in the Montreal West-Island area in Quebec - Canada. Thank you
  • 1073 Answers
SOURCE: Exploding Door
replace the glass it has had a fracture to it in the production cycle at the factory
Posted on Jun 09, 2008
appldoctom
  • 311 Answers
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Posted on Jan 05, 2009
aborcass
  • 2651 Answers
SOURCE: Glass door GE JGS968
youlls need to remove the door forom the unit and disassemble the outer door glass, not a major deal, al ittle patience will get it done if oyou would like to know how to do it exaclty youll need to send me the model number so i can look it up for a part diagram..
Posted on Jan 16, 2009
danromarris
  • 101 Answers
SOURCE: GE Hotpoint electric stove
If you ran a self cleaning cycle and now the door won't open you may just need to wait a while. The door locks to avoid anyone from opening it as the over heats up to around 700 or more degrees to burn anything off. Sometimes what will happen however is that the heat will get to intense and cause the door lock mechanism to jamb. If the door doesn't open for you after a good few hours or so you can try unplugging the oven for a while to try and reset it. If not though you will have to go through the front panel and go down to manually unlock the door. Let me know if you have any other questions and let me know if this was helpful. Keep me updated on the outcome too if you wouldn't mind. Good luck and glad I could help.
Posted on Jan 22, 2009
  • 52 Answers
SOURCE: GE Spectra XL44 burned cabinets during self cleaning
the gasket or seal is likely gone ...replace
Posted on Jul 25, 2009
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Apr 22, 2011 | Frigidaire 30 in. Electric Gallery Pro...
I used the self cleaning feature on my stove and began to clean with a wet cloth before it was cool and the glass cracked on the door. is this able to be replaced?
yes the glass can be purchased separetly call your local part store give them the model number and they can get you the right part
Mar 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Spill between glass panes on oven door
The only way to clean this is to dismantle the door. Most brands you can remove the door and set it on a counter to dismantle. This can be very complicated, depending on the brand and model. Leaving the gravy inside the door won't hurt the range, and self cleaning usually will not clean this completely. It usually just bakes it on harder. Good Luck Appliance Specialists
Dec 31, 2009 | Kitchen Ranges
I need to replace a cracked glass top (GE Profile Slide In... where do I find my oven model number and part number
If you dont see it around the door or inside the stove you'll have to raise the top and it should be there somewhere. The part number for the glass top I can get for you if I have the model number
Sep 08, 2009 | GE Profile 30" Self-Cleaning Slide-In...
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
How to self clean
Depending on the condition of the oven, it could take up to 4 hours.
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Here is a link for your stove:
GE JTP18 Manual
Directions are on page 23.
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
Self cleaning caused interior glass to crack
hi there,
this is called thermal breakage. basically, when the mfg. makes the glass, they either don't cook it long enough or let it harden long enough during manufacturing. remember, the glass is supposed to withstand over 1200 degrees, which is temperature during self cleaning. have a technician replace the door glass, as warranty should cover this.
thanks
Sep 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
GE 30" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel Logo
64 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
