Question about Air Tools & Compressors
I found a leak on my compressor central pneumatic 42321. its in the metal hose that goes from the engine to the air tanks. my question is where can i get this replacement part .
Ibought hose at harbor freight that was rated higher that the tank pressure and used that'd
Posted on Jan 20, 2014
    Master:
  • 343 Answers
Harbor Freight Tools, or take piece to hardware store and replace with copper flexible tubing and brass fittings that match
Posted on Oct 04, 2010
Central pnematic compressors, will not build up air
Use soapy water to check for air leaks. Can also check piston ring and valves. Make sure engine is driving the compressor.
May 19, 2013 | central pneumatic 212cc, 9 gal., 135 PSI...
I need a seal for central pneumatic twin tank 2hp iteam 42321. Where can I get it online?
Try this link......http://fitness.manualsonline.com/ex/mfg/headline/m/harbor_freight_tools/type/product_problem/
Mar 24, 2011 | Air Tools & Compressors
I have a Central Pneumatic, 21 Gallon, 3HP air compressor. The compressor is exiting air through exthaust port.
If air leaks when motor is off, fault most likely in-tank check valve. Follow discharge air line from pump to tank. Brass/steel valve at tank is the check valve. Remove hose to valve and check for leak. Replace as needed. If air is leaking while motor is running fault could be reed valves in head. Faulty reed valves in head, or torn head gaskets will cause very hot discharge air and tank will most likely never fill to shut off (or take a very long time to fill)
Sep 06, 2010 | Air Tools & Compressors
Need diaphram for regulator for central pneumatic 42321
I used a FORD master cylinder gasket number 42098. It is the right overall diameter and I used a hole punch, slightly oiled, in my drill press to put in the four screw holes. The hardest thing is getting the nuts back on the screws to hold the switch together. But it works for $5.
May 26, 2010 | Bel Aire Compressors Bel Aire 5 Hp Air...
Central Pneumatic 2 hp 8 gal compressor won't build pressure just sounds like leaking all the time where do i start to look for problem
if it is leaking air the check valve is bad.find the airline leaving the air pump follow this line to tank.this line attaches to the check valve which is screwed into tank.make sure no pressure is in tank when removing.
May 18, 2010 | Air Tools & Compressors
Central pneumatic 2 hp 4 gal air compressor has too many air leaks how to fix
can you please tell me where are the leak found as there are different place with dif temp seal
Sep 23, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
389 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
