Question about Samsung Cell Phones
Phone will not turn with charged battery - Samsung Cell Phones
  • angelshirley May 16, 2009
    Samsung phone not turning on or anything, after i put an animated picture as my wallpaper it started being werid and was confusing while it wasn't working properly. Soon the screen went black...i thought it turned of by itself, but it doesnt turn on or respond to me. When I charge it through computer or normal charger, you'll see that they still show you the light in that little circle, meaning its charging but the screen or the phone itself is not reponding.
Not turn
Posted on Jul 28, 2008
Why five rapid beeps and screen saying "charge battery"? I had turned on and was charging, and 1 day later phone off and charge gone.
The batteries are defective, your local supermarket should have rechargeable batteries or try an online auction site, look for the highest 'mah rating you can get something like 2800mah, the higher the rating generally the longer the battery will hold charge
Sep 25, 2014 | Panasonic KX-TD7896 Cordless Phone
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Bought new battery for cell phone, wont charge or turn on
did you try a new charger not the best solutinon
Jun 11, 2012 | LG Rumor 2 Cell Phone
Phone wont turn on, when it dose turn on turns its self back off and wont charge?
Have you checked the battery? May be it is very weak and that's why its not charging your phone.
Try to get some using the same battery with your phone, borrow his or her battery, and test it with your phone to confirm if the fault is from the battery or not.
And if you don't find someone to borrow you the battery, simply look for a desktop battery charger, remove the battery from the phone and charge till it gets full then insert the battery back into the phone and power it to see if it turns on.
Take care.
Nov 23, 2009 | Sony Ericsson Walkman® W610i Cellular...
New cell phone battery trouble
Dont talk or use mobile phone when the phone is charging its battery and charge your mbbile battery for 10 hrs continusly before intinal use Only Charge your mobile when it shows " LOW BATTERY " Dont over charge your mobile Use the mobile to talk only when the network signal is high else use sms facility to communicate Use only original charger to charge the battery
Oct 22, 2009 | Sony Ericsson TM506 Cell Phone
My jank phone, incapable of charging, turned off and wont turn on
As the phone keeps turning on off there is some loose contacts or some dirt is there at battery terminals try cleaning phone and battery contact terminals
Jul 21, 2009 | LG VX5200 Cellular Phone
Wont charge
it might be the battery. cause batteries on cell phones only last for so long [depending on how long you've had it] or you might just have a bad phone. go to the phone company where your phone is from, and tell them about it, and they'll probably give you a new phone.
May 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
Won't Charge or Turn on
First try drying out your phone for a day or two with lots of dry moving air gently blowing past and around it, the phone must be unplugged and battery removed during this process, then once everything has been dried try charging the battery in another phone just like it, if it charges and see it it will power the phone, if the battery works put t back into your phone and try to turn it on. If it doesn't work in your phone but it does in another then its the phone, if the phone works with another battery its the battery but dry them both totally first, even a few tiny specs of moisture can screw up your phone when power is running through it, so be careful. Cheers!
Mar 02, 2008 | Motorola Mobility RAZR V3
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
308 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
