Question about Solar 10 Eagle Almond Commercial Double Pole Light Switches
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light bulbs barely come on. I think it may be the switch so I got a new light switch but cannot figure out how to wire the dang thing. It only has the two screws on the side. The dimmer has black, red, yellow and green wires. The green isn't hooked to anything (apparently whoever put it in failed to connect the ground), the black dimmer wire is hooked to an incoming bigger black wire, the yellow dimmer wire is hooked to a red wire, and the red dimmer wire is hooked to a smaller black wire. What do I hook together to get this dang thing to work? I have put in a dozen ceiling fans over the past few decades but never messed with a stupid dimmer switch. Suggestions would be appreciated.
  • Lawrence Oravetz Dec 07, 2014
    Never use a light dimmer to control a motor. It will eventually burn up the motor(personal experience here).Use a motor speed controller or better yet add a remote control to your fan. Makes the wiring problems go away.You can obtain the remote control from any home improvement store that sells ceiling fans.
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Posted on Oct 04, 2010
Testimonial: "Thanks That definitely helps..."
Living room wiring. All the outlets and the bright overhead light fixture are all wired to a wall switch, so you can't have any side lamps on without the overhead light. How do I understand this so I can...
The most common way the houses are wired is through the ceiling. The power comes into the box that the light is on. The power is wired to the light on one wire and the other goes down to the switch. The return comes back from the switch and connects to the light. What the did was connect the wire that feeds the outlets to the switch.
Aug 16, 2014 | Electrical Supplies
Room has wired 3-way switches, but light fixt is missing. Fixt box has 2 sets of wires (2-wires + gnd) coming in. How do I connect a simple light fixt?
You probably had a fan/light fixture there. One set of wires (probably coming from the dimmer) would be for the light. The other set of wires (probably coming from the switch) would be for the fan. With the power off, temporarily hook up two lamps, one to each set of wires. Then turn on the power and see which switch controls which wires. It is possible that one set of wires is passing through to another light fixture - in that case, that wire will be dead. Good luck!
Dec 07, 2012 | Lutron Electrical Supplies
I installed a single pole rotary dimmer in my dinning room about a year ago. It controls a fan and a dimmer 4 bulb lamp. I used this fixture maybe once or twice a week, and only occasional times we used...
Rotary dimmers are not normally suitable for fan control plus not all types of lamps are dimmable , so used wrongly a dimmer could catch fire.
Steve
Nov 07, 2011 | Electrical Supplies
I'm installing a vanity light in the bathroom. The old one had a dimmer attached. For the new fixture, attached two white from the wall to the white in the fixture. attached two white from the wall to...
Get a test light, a bulb in a socket with a black and a white wire. disconnect both the black and the red. Also have access to the white or the ground. Then with the power hold the white test light wire to the white of the house and the black to the black. .turn the dimmer on and off and see if it controls the light. NEXT do the same with the red, that is test light black held to red and test light white held to house white. once again check the dimmer.
Typically when you have a hot red and a hot black in a fixture the black is on the dimmer and the red is always on because it is connected to an outlet built into the light. OR the light can be controlled from two locations, one regular switch and one dimmer switch.
Mar 01, 2010 | Electrical Supplies
I have a live 2-wire line that used to be connected to a light with a switch built into the light fixture. I removed the fixture and put wire nuts on the live wire. What I'm trying to do is to wire the 2...
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
Oct 17, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
Test on rear EXIT sign in rear exit of boiler room.
The red LED backup should come on when the regular light goes out. Maybe the battery has not charged up yet, or is defective.
Oct 11, 2009 | Universal Battery Exit Sign Red Led ...
3-way dimmer dead
It could be a loose connection, and it could be a loose connection on the OTHER 3-way switch across the room. Also, verify that the dimmer is rated for the fixture(s): add together the wattage of each individual light bulb that the dimmer controls and make sure that the dimmer has a higher wattage rating. If it isn't, you might have burned up your dimmer (and risked an electrical fire). Hope this helps!
Aug 31, 2009 | Leviton Decora Light Dimmer Switch
Light switch feels hot
If the switch is rated at 600 watts and you have six 100 watt lamps connected to the switch, you are at the capacity of the switch and heating would be expected. It's general practice to not place loads on a device that will exceed 80% of the device's ratings, in this case 480 watts.
Some heating in a dimmer switch is not unusual, but if it's hot, it should be replaced with a device with a higher rating or the loads should be divided. You could also lower the wattage of the lamps (to around 75 watt each) unless you would lose too much light.
If the sockets in the fixtures can be lowered closer to the surface of the fixture, you can probably reduce the wattage since more light will exit the fixture. You will also save a few bucks with less wattage. Lastly, check the fixtures themselves and see if they are rated for the wattage of the lamps you have in them.
Apr 14, 2009 | Lutron 1000-Watt Incandescent Dimmer...
Solar 10 Eagle Almond Commercial Double Pole Light Switches Logo
236 people viewed this question
Top Solar Electrical Supplies Experts
Steve
Lawrence Oravetz
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
