Question about Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor
Hi what happens is i turn on the compessor it hums only then the thermal cutout cuts out after 10 seconds or so i turn off reset thermal cut and try again same thing happen thank in advance
    Master:
  • 343 Answers
You may be drawing too much current thru cord causing relay to trip, plug compressor cord directly into 20 amp circuit. As these tools get older and used the motor windings get hotter. Try pumping up with no pressure in tank and tank bleed valve open. I have experienced this dozens of times with many makes of small to mid-sized compressors.
Posted on Oct 04, 2010
My bosch microwave HBC84E653B cuts outs suddenly after 10 seconds.
A thermal cutout could be shutting it down. Check to make sure the cooling fan on the magnetron is functional.
Jul 08, 2016 | Bosch Microwave Ovens
I recently purchased a 20 gal/1.5 HP, model 921.166420. The reset button on the side of the motor, (thermal overload Protector?) cuts out repeatedly. The few times where the motor did run and the pr
Could be weak thermal cutout or actual problem with unit. Thermal cut out easy to check with amp meter. Connect meter as required to monitor draw as unit fills and make sure that it stays at or below usage stated. If amp draw stays below stated usage and thermal cuts out, replace the part. If amp draw goes over amount stated turn off compressor and listen for air leaks (usually check valve will leak back pressure to pump causing extra load on motor).
Nov 29, 2011 | Craftsman 150 PSI Air Compressor
My cuisinart brew central, 8 yrs old and still going strong - until now, just turns off after brewing 1/2 pot of coffee. I can turn it back on easily by hitting the toggle swithch. Just started to do...
Hi, Eight years is unreal. I was going to suggest that the boiler elelment i s starting to fail, but i think it could be a thermal cut out which is positioned on the boiler. Thermal cutouts are connected to the main toggel switch. The thermal cutout turns of the power when activated. You can check it wity a meter (approx 12kOmhs). Id replace the thermal cut out anyway. They do ware out.
Sep 26, 2011 | Cuisinart DCC-1200 Coffee Maker
On our AE125, the thermal cut-off is tripping AFTER the water is turned off. The heating element is getting so hot you cannot touch it
The elements are getting over heated then set temperature.You have a defective thermostat. The elements will continue to heat until they reach the set point of the thermostat. Try to lower the temp setting first. If that does not fix it, you'll need to repalce the thermostat, located very near the element, under the screwed cover on the side of the tank.------------- To know how this heater works, read as follows:---
Because electric tankless water heaters have to instantaneously raise the temperature of incoming water to a selected hot water temperature, they require very powerful heating elements. To power the heating elements of this 27,000 Watt model, you will need to upgrade the electrical service you were using for your storage tank water heater. The PowerStar AE125 will require a 240V, 200 Amp service. In addition you will need to install three 40 amp dedicated double pole breakers in your electrical box. In Canada, you will require one 120 Amp breaker.
The PowerStar AE125 electric tankless water heater incorporates a very sensitive flow sensor, and three heating elements. The heat from the electric elements is electronically modulated on the basis of the flow rate of the water entering the water heater, and the temperature rise that the water heater must achieve. Through its electronic modulation system, the AE125 maintains a very precise hot water temperature. As a safety precaution, each of the three heating modules is protected by an electro-mechanical thermal cut-out. This device will cut power to a particular module if the temperature gets too hot.
This will help.Thanks.Helpmech.
Jul 02, 2011 | Heating & Cooling
The oven hums and then shuts off within about 5 to 10 seconds of being started no matter what power level or time is set. The "keep warm" setting will run for the amount of time set but the food...
hi there
unfortunately your magnetron has failed and the thermal cut-out located on the top of it is cutting in to prevent overheating and possible fire risk.
regards
ian
Apr 17, 2011 | Microwave Ovens
Dometic Duo Therm Ac, Fan runs, Compressor cuts in and out?
your compressor is locked up. i would try replacing the round start capacitor. you need to check what the exact rating for yours is but I believe one of these two will work for ya. In the meantime do not continue to try to run it, it will kill the compressor.
seth
53-64 mfd
45-53 mfd
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Microwes panasonic nn-t553w
hi, check that the cooling fan is operating and to sufficient speed to cool the magnetron or the thermal cutout mounted to the magnetron will cut power
Mar 06, 2009 | Panasonic NN-S753 Microwave Oven
Possible reset on Thermal Cut-Off
This is not really expert advise but I have a vaccuum with hepa filters and if the filters get dirty My vaccuum acts like your what you are describing.
Jan 07, 2009 | Eureka Vacuums
The heating element turns off after about 2 mins
the most common cause for thermostat problems is lint build up. in the exhaoust duct, in the vent hood on the outside wall, in the squirrel cage fan
there is not enough air moving past the heater element to keep it within normal operating ranges, the thermostat cuts it out.
when the reduced air flow cools the element below max, it cuts in, overheats the thermostat and cuts out, for the whole timer cycle.
clear the exhaoust ducting, fan and vent hood of all lint
and try again
If there is too much overheating a firesafe device thermal cutout will trip and does not reset
locate the thermal cutout, a small device that looks like this 39ec5e4.jpg or this 9756eee.jpg screwed to the exhaust duct or fan housing. not resettable, test with ohmmmeter or battery and bulb,
the local parts guy will have the part, there are only a few for all the different dryer models
probably 75% chance of fix
Apr 20, 2008 | Roper REX4634KQ Electric Dryer
RESET SAFETY CUTOUTS
The thermal cut-outs are not resettable. You can by-pass them to check the operation but you still need to replace the bad cut-out.
Jan 08, 2008 | Dryers
Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Logo
260 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
