Question about LG enV Touch VX11000 Cell Phone
When i power on my lg vx11000 all that displays on the screen is (battery required) and the thing is the battery is fully charged and indeed attached to the phone correctly?? plz help
  • 629 Answers
Try to turn it off, remove the battery, then press the power switch for about 10 seconds. After that, connect the battery making sure the contacts are okay, then switch on the phone again and see how it goes. hope this helps and your rating/comment would be appreciated.
Posted on Oct 04, 2010
Battery in bangladesh
Posted on Mar 18, 2011
On the Alcatel a206g, how can I tell when the battery is fully charged? Does the light change color?
When the battery is fully charged the image of a battery
will display on the screen with 4 bars.
link to on line pdf manual
Alcatel A206G User Manual
Jun 02, 2016 | Alcatel Cell Phones
OBJECT ERROR RESTART CAMERA
If you did not obstruct the lens, would think there is a battery problem. Digital cameras require lots of power. As you call on it to do more things like extending the lens and focusing the power requirement goes up.
I had a similar problem with my camera and finally discovered that the problem was with the battery to camera electrical connections. I cleaned the contacts as described in the source link about two months ago and have not had a problem since.
The following excerpts came from the source link. Hope this helps!
Most cameras will reset to original settings if batteries are removed for at least one minute. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
The secret to making digital cameras work better is having good electrical contacts between the batteries and the camera.
Digital cameras require lots of power. If electrical contacts are not really good, this can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD display is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. With bad contacts, cameras do strange things like making bad pictures or shutting off with the lens out.
To prevent overcharge, use an automatic two or more hour battery charger with safety timer, temperature monitor and trickle charge technology ($9.78). For longer life, NiMH batteries should be charged often and kept in active use. To preserve battery charge, use the view finder and not the LCD display when possible. Maximum capacity is reached after 2 to 4 charge/discharge cycles.
http://www.google.com/base/a/4210404/D13...
Mar 13, 2011 | Canon PowerShot SX100 IS Digital Camera
Ok every time my phone says low battery i go and charge it and like in about 45 min it will say charge complete so i grab and take it with me and go take like one 30 sec video it says low battery and i...
Your phone's battery has most likely reached the end of its life. Luckily, replacement batteries for the enV Touch are very inexpensive. Here's a battery that will work with your phone, for $8.00, and free shipping. I am not affiliated with the seller.
http://cgi.ebay.com/NEW-OEM-LG-LGLP-AHLM-EnV-TOUCH-VX11000-VX11k-BATTERY-/260745505647?pt=PDA_Accessories&hash=item3cb5a4ab6f
Mar 06, 2011 | LG enV Touch VX11000 Cell Phone
How do i fully flash my lg env touch vx11000 cell phone to cricket wireless
Since they dont offer the exact same model you cant fully flash to cricket
Jul 10, 2010 | LG enV Touch VX11000 Cell Phone
Simply....The phone refuses to turn on
first thing i would try is some kind of electrical contact cleaner. spray a little on a tooth brush, and clean the charging port. do this with the phone off and battery out.
Apr 17, 2010 | Verizon Communications LG VX8350 Cell...
Shortcut menu button on VX11000 is stuck in the upper left corner of the display. It does not respond to taps, and can't be moved on the display. The rest of the dsiplay operates normal. Performed a...
Your phone may need professional adjustment. Please take your device to the professional repair shop located within most Verizon sales areas.
While there, ask them to update your software.
Thanks for posting your question at FixYa.com
Nov 16, 2009 | LG enV Touch VX11000 Cell Phone
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
LG Voyager won't reboot
Interesting, normally the screen only appears with water damage, which I am sure Verizons customer service has continued to tell you that is the cause without thinking the customer might not know for themselves, The only way to fix this is to got to a Verizon Wireless store and ask them to do what is called a software flash, now it may delete all your information on your device but at least it will work, if you need any more help with this let me know.
Jan 02, 2009 | LG VOYAGER VX10000 Cellular Phone
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
YP-T9 constantly charging?
if you recharg it too much it could be wearing down, I'm guessing. unless oyu just got it.. you should take ti back because that's just messed
Jul 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
LG enV Touch VX11000 Cell Phone Logo
990 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
