Question about Bosch Axxis WFL 2060 Front Load Washer
I think I put bleach in the wrong slot. Lots of suds in my washing machine. What should I do?
    Sergeant:
    Champion:
  • 351 Answers
Run it don't put soap for a couple times
Posted on Oct 04, 2010
How do I get my clothes to SMELL like clean clothes? Darn washing machine stinks them up!
Check the drain where ti empties into, smell the drain thats most likely where the odour is coming from.
Aug 18, 2014 | Maytag Centennial MTW5800TW Top Load...
My washing machine gets a sud error often during the cycle. I have cleaned the drain as suggested
Vinegar does a great job of cutting suds and bubbles. I would put it in the detergent, softener, and bleach reservoirs and run a cycle. Then make sure you read the detergent amounts. It's easy to overdo detergent on a front-loader.
Aug 17, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Duet washer , clean filter still get sud reading. Washes well without clothes. Wash with and without soap and did not put in clothes. The machine went throught the cycle with no problems. When you
do you get a lot of suds when you run it without soap and clothes ? if so put about a cup or 2 of vegetable oil into the washer and run a cycle . soap suds will adhere to the oil and it will help it to remove from washer . after you can run a clean cycle with bleach or white distilled vinegar.
Feb 20, 2013 | Washing Machines
Suds, and F35 keeps coming up when trying to wash!
I would put bleach in the detergent slot, run through each cycle. Then run the cycle again with just water. These are really touch when using detergent. Just a little bid of suds sets these things off.
Jul 26, 2010 | Kenmore 44102 Front Load Washer
I DONT KNOW IF THIS A PROBLEM FOR THIS WASHER
Your display was probably displaying "SUD". This is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use minimal amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Mar 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a HE5t kenmore elite front loading washer. It has done great for about 15 months. We were away for about 3 weeks, and since we have returned, I put in a load of clothes, and it tries to start...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%^*
Aug 27, 2009 | Kenmore HE2 Plus Front Load Washer
Dont' know where to add bleach alternative
yes clorox 2 or "dry type" bleach should be put in with the detergent. only liquid bleach will go into the bleach dispenser.
also be sure to use soap that is "HE" type or you will get too many suds and a washer that will smell from not rinsing out.
Mar 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Axxis WFL 2060 Front Load Washer Logo
214 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
