Question about Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder
It turns on but just for 30 seconds and then it turns off, it says before get off DEW DETECTED, EJECT TAPE
Just put it in a pillowcase or something, then put it in a bigger bag and pour some rice in the bigger bag so that the most of the camera is covered. I left it to dry next to a stove(NOT TOO CLOSE, just near enough that it will be warm). It helped, mine was in the bag overnight and now, in the morning it's okay. PS! you might need to clean your video heads with a cleaning tape after the cam's dried!
Posted on Oct 17, 2010
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 05, 2010
I have a Sharp ViewcamZ VL-Z900. DEW error
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Sep 18, 2009 | Cameras
"Dew" sitting on my Video Camera
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Mar 13, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Camcorder panasonic displays dew detect in red
Eject the tape. Leave the tape carriage open. Power the unit off and tent it with a light linen cloth for about 20 minutes in a warm but obviously low humidity area. Emergency/ short time approach: Clean hair blow-dryer. Set for warm/low heat. Turn on and "wave" the warm air into the tape mechanism section about 18 to 12 inches away from the camera's open gate/door. Bake for 3-5 minutes..
Jan 14, 2009 | Panasonic PV-GS39 Mini DV Digital...
Dew detected eject tape
como puedo solucionar el problema (how can I solve the problem)
Dec 19, 2008 | Panasonic PV-DV103 Mini DV Digital...
Panasonic DV mini camcorder error message
Inside is a sensor that detects moisture. If there is dew inside the unit, the tape will adhere to the head and create all kinds of problems. This sensor is there to to prevent problems. That being said, the repair for this could be as simple as ejecting the tape leaving the unit open and letting it dry out. It could also be a bad sensor. In the case of the sensor, the parts cost would be in the $10-$20 range. Add in the local labor rate ($175 here in Mass) and you have the total repair cost. While this is not the easiest repair because of its size, anyone that works on camcorders will find it straightforward.
Dan
Sep 12, 2008 | Panasonic NV-DS60 Mini DV Digital...
DEW DETECTED / EJECT TAPE
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Jun 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
Nov 13, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew detected on DV-203
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works! When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
Sep 09, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew detected error signal
Good Luck,
Luwangula
Nov 11, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder Logo
111 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
