Question about Fisher and Paykel (IWL12)
My washing machine is showing fault cade 40. what does this mean?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now ERROR CODE 40 is called Bowl Dis-engage Fault.This means that the clutch has not re-engaged to start the machine on a spin cycle.There are 4 things to check on your machine to establish where the fault is located.The 1st is the clutch,the 2nd is the pressure switch tube,the 3rd is the control module and the last your machine has too many suds in the bowl.Would you like me to help you test all of these things in the list?Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Posted on Oct 04, 2010
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Fault cade 96
cade = code?
and 96 the code or the year?????????????????????????????
and dyna heavy truck
built 1979 to present, vast forms. what is yours.?????
no engine stated.
my motto:
NO YEAR?
NO MODEL (dyan)
No engine size. (or transmission type A/T or M/T?, if that is in question)
NO HELP (or your joy)
No country , too , is a royal pain , all cars are different by country (laws)
Jan 10, 2014 | Toyota Cars & Trucks
H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
Jan 23, 2013 | Washing Machines
E4 error cade my whirlpool ww1307
my washing machine doesnt have a display in the control panel..sometimes it works sometimes no..anybody can help me...whirlpool ww 1307
Jun 16, 2012 | Whirlpool Washing Machines
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
I have a whirlpool washing machine with a fault code F23. Can anyone advise me what it means?
HEATER FAILURE
If the temperature increase during the first 40 minutes is less than 86°F (30°C).
1. Unplug washer or disconnect power.
2. Check connection to water heater.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
4. Check the water temperature sensor and connection to it.
Nov 27, 2010 | Washing Machines
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Washing Machines Logo
457 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
